Question about Fujitsu Siemens LifeBook S6120 Notebook
Where is the Cmos batterie. What s the easiest way to change?
  • siegfried_re Jul 26, 2009
    looking to the bottom of my Fujitsu Siemens S6120 there isnt that compartment.
    I only see on Compartmet 2 screws Drive aera; One bigger comartment for Main Batterie; One combatrtment with 2 Screws for 2 Ram Banks That is it
    sig
    President:
  • 1,564 Answers
On the bottom of the laptop there should be a square panel about 1.25" square. It will have only one small phillips screw holding it closed. Open the compartment use a plastic fork to slide the battery out , taking note of it's polarity,(which side is up) they are availabl at most hardware and Radio Shack stores.
Posted on Jul 26, 2009
Where is the cmos battery on toshiba satellite laptops
it is inside in the computer, need to dis-assemble it and you will find on motherboard
Jan 08, 2013 | Toshiba Satellite P305D-S8900 Notebook
No signal on monitor, keyboard num key not on/off CPU is running
some bios problem try reset bios given method
The easiest way to clear the CMOS is to enter the BIOS setup utility and choose to "Reset BIOS Settings" to their factory default levels
Yet another way to clear the CMOS is to reseat the CMOS battery. By removing and then reinstalling the CMOS battery, you remove the source of power that saves your computer's BIOS settings.
apply any method and try
May 19, 2012 | Computers & Internet
How can i reset the cmos in my ms200 all in one computer?? it shows that my hasrd drive is not working, and it is really working in other computer
To reset the CMOS the easiest way is, remove the motherboard battery for ten minute then install it again. It will clear the CMOS. Then reset the CMOS/BIOS setup, date/ time etc. Another way to clear CMOS is, reset the CMOS Jumper in motherboard.
To detect your hard drive you can try to check by change the hard drive cables. Change the port in motherboard. Check the BIOS setup and reset it if need.
Jul 06, 2011 | HP Pavilion AllinOne MS214 185" Desktop PC...
ASUS A3H notebook: how do I reset the bios password. First, I press F2, then I'm able to get through the bios, then I changed the password ( I didn't place any or no password at all, just pressed...
Well..... It thinks there is a password. Have you tried just pressing the enter key? If so, then you have to reset the CMOS. To do this you will need to disassemble to get to the CMOS battery. I could have a jumper but the easiest method is just to pull the CMOS battery. On older laptops it is a rechargeable battery (nicad or lithum) and on newer ones they use a coin cell battery like desktop computers.
Best of luck, Jim
May 07, 2011 | ASUS A3H Notebook
What is code F on the motherboard
looking around at various forums, it seems that the easiest way to clear this code would be to clear the cmos (bios settings) the easiest way to achieve this is to remove the cmos battery overnight then refit, this should have then cleared the cmos ready to boot the machine
I hope this is some help, I know it doesn't answer your question but hopefully will solve your problem.
May 06, 2011 | Abit FATAL1TY AA8XE
How to reset cmos or bios
Hello Friend,
There are a few ways.
The easiest way is to enter the BIOS setup screen, and select the option to reset to default settings, it should be easy to find or it would be on the save changes sections.
If you can not access the BIOS setup screen, it will take physical access to the computer's motherboard. This means you will need to open up the computer case. From here there are a few options that you can do.
change the the CMOS jumper to reset.
Press the CMOS reset buttion
Or remove the CMOS battery for a few minutes.
Please note that not all manufacturer have a jumper setting or cmos reset button. Also a CMOS battery looks like a button battery.
Also if you are going to open up the case, make sure the computer is off, unplugged, and if this is a laptop the battery must be removed. Good Luck!
Dec 20, 2010 | Computers & Internet
How to clear CMOS password on Lifebook E8020d.
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 09, 2010 | Fujitsu Siemens LifeBook E8020D Notebook
I need to reset cmos to wipe out passwords.
The easiest way I know of to reset the cmos is to remove the cmos battery and leave it aside for at least an hour before re-installing. That should clear all your settings.
Aug 28, 2009 | Acer Aspire 1642WLMi Notebook
Fujitsu Siemens LifeBook S6120 Notebook Logo
403 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
