Which compartment in the drawer do i put my powder?
  • 42 Answers
Hi
inside the machine, there is a small compartment at the side or in the middle where you can add detergent. refer your user manual for the exact location.
cheers
Posted on Jul 26, 2009
Excell 7 VarioPerfect: fabric conditioner compartment will not drain
perhaps you need to contact Bosch website for tech support
Sep 21, 2016 | Bosch Washing Machines
Kenmore HE 4t Elite Front Loader Washing Machine
Inside the dispenser drawer, at the bottom there is a tab that you can push down to remove the dispenser drawer. Remove the drawer and check if the dispenser holes are clogged, this is a common cause.
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
There is caked washing powder let over in the tray after every wash and the clothes are not being washed properly. How do I fix this?
read the user manual for the right section to use
if you do not have a user manual then go google and type in ---user manual for ( make and model of machine ) and download a pdf version
personally washing detergent powder causes more problems that what it is worth
change over to liquid detergents
Oct 28, 2015 | Washing Machines
When should fabric softener be put in drawer
You can put it in at the same time as you put the wash powder in before you start the wash but make sure you put it in the right compartment of the drawer.
Dec 22, 2012 | Siemens Washing Machines
My washing machine won't use soap from the drawer
are you useing the right draw for main wash try putting on a wash and open the draw there should not be any water leaking if you do this and look in the compartment that you put the powder in and see if the water is going into the compartment that you use and see which compartment is filling thats the one to put the powder in
Nov 14, 2011 | Washing Machines
I have just bought a second hand front loader which compartment do I put wasdhing powder in and what are the other two compartments
Hi from retired Englishman in SW France @14:24 Wed afternoon,
I am presuming you do not have a manual- most manuals can be obtained on-line. I think there is an advert somewhere on this site! No! No commission!
3 compartments - pre-wash powder, wash powder and finally conditioner/softener. As you do not say what make and model yours is we will 'cheat' a bit to find out which is which!
If you pull the drawer out just enough to be able to see into it, then put the machine on pre-wash for a few seconds you should be able to see into which compartment the water is running! Do the same with the main wash. You are then left with the conditioner one which, when you look at the whole drawer, one looks distinctly different from the other 2. With our Bosch it is in the middle but with our daughter's (can't remember which make it is!) the conditioner tray is on the right.
John C
Feb 02, 2011 | Washing Machines
Washer doesn't dispense fabric softener
This can be either one of the solenoids in the dispenser has failed, the timer is not sending the signal to let the softener in, or the water is not circulating through the dispenser to flush it through. The water hose to the dispenser will occasionally plug up. Check the hose first, it's the cheapest to unplug it. ;-) Oh, I have seen the wires to the solenoids just simply come unplugged too.
Jan 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Where do i put washing powder in hotpoint aquarius 1000 three compartments in drawer what solutions go in what compartment
with experience, put powder in the first, softner in the middle second, pre wash in the third, but with that model i find its always best to use a liquid or gel direct into the machine, it makes the life of the machine last longer, also stops any build up residue
Jul 18, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Bosch axxis washing machine detergent symbols
There are usually 3 compartments in the drawer, the smallest is for using fabric conditioner, the largest is where you put the powder or detergent in, the middle size one you do not put anything in, as it is where the cold water comes in for rinsing.
Plz rate my solution.
Thanks.
Jan 26, 2009 | Bosch Logixx WFT 2806 Front Load...
Soap powder remains in the soap compartment
Depending on which compartment the powder is remaining in, it could be low water pressure causing the problem.
If it is taking some down, but not all the powder, then try putting the powder towards the front of the compartment.
If all else fails then I suggest you get one of these dispenser balls that you put straight in the drum with the washing.
Plz rate this solution.
thanks.
Dec 28, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
