Question about Refrigerators
Whirlpool not cooling properly
My Whirlpool ED25RFXFN00 side-by-side seems to stop cooling at some point. I noticed the top quick freeze shelve, which had ice cream on it was starting to thaw and the ice seemed a little bit melted. I rotated the thermostat switch for the box side and the compressor came on and started cooling. I also checked the condenser coils, which were clean and bot the condenser and evaporator fans are running, when unit is operating. I checked the internet and did a defrost mode test, by rotating the defrost timer into defrost. The defrost heater comes on and defrost for about 20-25 minutes. This seems long, started defrost at 6:55 and went back to operating at 7:17 pm. I wondering if there is a problem with box side thermostat, intermittent defrost timer or bad defrost/thermostat thermal switch. Any suggestions? Thanks
  • 42 Answers
I would expect the defrost timer to stay in defrost 21 minutes. IT seems your timer is normal.
If turning the ref section temp colder made compressor come on, it could be that the thermostat is worn a little and just needs to stay on a little cooler setting. Check the freezer temp dial and It should be at just slightly more than 1/2 of available setting. If there is A B C you would want to be a little cooler than B about B and 1/4.
I hope this helps K S
Posted on Nov 22, 2007
Freezer compartment works okay but refrigerator compartment gets warm. Pulled bottom shelves and noticed ice build-up. Not sure of the problem. Any ideas and solutions?
Hi, it sounds like the thermostat for the refrigerator is not shutting off and just continuing to cool to the point of freezing . You need to get it checked out and renewed .
Jan 07, 2016 | Bosch B22CS80SNS (220 cu ft) Side by Side...
Top 3 shelves don't freeze
Cold air sinks. If evaporator temp is not low enough only the items on bottom of freezer will get cold and possibly freeze - stuff on top will not.
Throw a digital thermometer in there towards the top shelves and I bet your temps are high. Low refrigerant will cause this; furthermore, if you leave the refrigerator door open by accident, the refrigerator will never shut off, the freezer evaporator will freeze over with a block of ice, and the freezer temps will be higher. If that is what happened, simply unplug the unit and allow it to self defrost and then turn it back on for proper operation and make sure that the refrigerator door is properly closed!
Nov 20, 2013 | Whirlpool Freezers
Kichenaid superba architect is warm up top
Check your freon level you can buy piercing valve for about 5 dollars low side pressure should be 11or12 on 134a after about 5 years I have found it sometimes seeps out of compressor
Sep 30, 2012 | KitchenAid Superba Architect KSCS25INSS...
The freezer seems to be defrosting into the refrigerator instead of into the drip pan under the fridge. Water is leaking onto the top shelves and eventually falling onto the bottom shelves.
That sounds more like your cooling tubes are frosting up and then when enough air flow is restricted then it melts out into the refrigerator side.
If I am right, If you take some bare 14 gauge wire and insert it down the cooling tube and then put a loose "hook" around the defrost heater, this will solve the problem permanently.
Jul 25, 2011 | Whirlpool Refrigerators
GE profile side by side is freezing fresh food and not cooling items on top 2 shelves
ge profile side by side is freezing fresh food and not cooling items on the top 2 shelves
May 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
My ED25RFXFN00 is running constantly.
sounds like your board in the back by compressor needs replaced
Mar 17, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Item in fridge freeze at the bottom, but barely cool at the top
has the cold air circ fan stopped or jammed? this will allow the cold air to drop to the bottom and not circulate.
Mar 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
241 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
