Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
What is the trick for getting the 2198597 ice maker back into its brackets?
  • sstanley13 Jul 26, 2009
    Thanks! I'm an idiot. As soon as I posted this I realized that I just wasn't shifting the right hand side far enough to the right. I appreciate you taking the time. I just hope the icemaker works now that it is completely defrosted. We had a repair guy come out- he took it out and never returned.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 162 Answers
This icemaker sets in sideways. attach plug and set in left and right side grooves. move right and left, it should go in easyly.
Posted on Jul 26, 2009
Dumping ice
If heater element is open the newly made cubes will stick to the tray and not be pushed out by the fingers doing the ejecting.
Apr 08, 2014 | Whirlpool 2198597 Ice Maker
Ice maker will not dump the ice.
if the auger is not turning the ice will not dump
Whirlpool Gold icemaker won't make ice
Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
If the ice maker does nothing then replace the=>
2198597 Ice Maker Assembly
Thanks John Tripp Appliance 911
Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
There is ice in the ice tray but will not dump
da7a4823-cd31-448f-bac2-11ff8c3d6b4e.jpgCan you confirm your refrigerators model number? If youre model is the KSCS25INSS there can be two possibilites. The Electronic Ice Level Control Board or the ice maker itself=> 2198597 Ice Maker Assembly Instructions on how to diagnose the ice maker and the Ice Maker Level Control can be found HERE I am here if you have questions, Thanks Sea Breeze
Oct 04, 2013 | KitchenAid Superba Architect KSCS25INSS...
My whirlpool ice maker heater sayed on an flooded the kitchen,could timner stuck.
Sounds like your ice maker is defective, Here is a Whirlpool ce Maker Manual
The PDF above may be helpful because it shows what to look for
in diagnostics on the Whirpool Ice Makers. I will be here to answer any questions you have, Sea Breeze
Feb 12, 2013 | Whirlpool GS6SHEXMB / GS6SHEXMQ /...
Not making ice,checked optics ,good ,water valve coil tested good, no restrictionsbut i get no water in tray,also freezer temp is 8 degrees.
OK you mentioned the ice maker had no cubes or not making cubes, try filling tray with water from tap. Let freeze and if the ice drops into ice bin the ice maker is OK. Most times the ice maker thermostat is at fault (pt. 27 in photo) if not cycling. Read OHM's between both coils and they should be very near to same reading, if not replace water control valve=> 4389177 by applying first 120VAC to see if valve opens. If water goes into ice maker this way or OHMs between the two are nearly the same your Ice Maker=>2198597 Ice Maker Assembly may need replaced. If you would like to rebuild your Ice Maker here are the part Breakdown view=>
GS5SHAXN Ice Maker Replacement Parts
Let me know how your ice or water turns out, Thanks Sea Breeze
Feb 11, 2011 | Whirlpool GS5SHAXN Side by Side...
Ice maker is leaking water and making ice cycles in the freezer.
the unit need to be replace some time its start leak and the only solution is to get a new one unless something got stuck in it and the water just coming out...the part# is 2198597 i think and it is 160$ at sears parts
www.911servicetoday.com
Dec 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
What model of replacement ice maker do I get for the Whirlpool GD5RHA side by side
Your model requires a part number 2198597 for the complete ice maker. Click here=> Point and Click Appliance Parts
75fbfb0.jpg Thanks, Sea Breeze
Oct 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Need to replace the ice maker part # 2198597. I need the instruction manual. If anyone can email to me that would be great mdelahan@comcast.net
there may be a seperate pump for the ice maker in the back at the bottom .itmay be cloged due to calcium or other debries check there first.as far as the ice maker,usally it just takes a few screws or a 1/4 in.socket to remove and then a unplug the connection. that motor may need to be checked as well.hope this helps
May 28, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
124 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
