SOURCE: h350 bluetooth headset can't connect to laptop any solution
first insert the bluetooth devices in the usb port.second open your disk drive and install the software from the cd. Then press on " connect"
SOURCE: connecting bluetooth headset
You have to go through a process to pair the devices.
Firstly:
Make sure bluetooth is turned on on your laptop (varies for each model)
Make sure the headset is fully charged.
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Then goto the bluetooth control panel and select "Look for Devices" or similar. Wait until the device has been found and when it asks for a passkey, enter 0000 and press okay.
see some more info at: http://tinyurl.com/2bz7hc
SOURCE: bluetooth ps3
MASTER RESET
At front of the receiver there is a button. Press it down
for 2 seconds. Next on the controller, hold the left 2 shoulder buttons down
WHILE re-inserting battery. Press the SQUARE button. Your controller should be working as normal.
SOURCE: bluetooth headset connection
Stereo earphone report the number of incoming calls remote control self-photographing song switching/pause redial of the last number connect with mobile phone hold down the power button until the red and blue lights flash alternatively.open bluetooth of the mobile phone to search bluetooth model.Click connection. http://www.thewishbuy.com/charmsonic
