Question about Kitchen Ranges
Oven's ignitor is bright, I smell gas, but it won't lite.
I have a Amana ARG7102 gas range,when I turn on the oven I smell gas and the ignitor is bright,but it won't lite
I would suspect that the problem can be not enough amperage in the ignitor (not hot enough to ignite the gas), but I'd like to hear expert's opinion before I order the part (I beleive, it's bake ignitor 31940001).
    President:
  • Kitchen Ranges Master
  • 1,922 Answers
If ignitor is brt orange to white its hot enough to ignite gas,either the flame sensor is giving wrong signal to control board and not opening gas valve or signals the gas valve to shut off gas before ignition,also your flame sensor could be faulty or control board is bad
Posted on Jul 28, 2009
Oven not firing up at all
Does the ignitor glow white hot and try to lite? If not, replace the ignitor. Here is that part to order. Whirlpool 74007498 Oven Ignitor AppliancePartsPros com
Mar 03, 2014 | Amana AGR5725SDS Gas Range
Smell gas when oven lit
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 09, 2010 | Amana ARGS7650SS Gas Kitchen Range
Amana AGDS902SS Gas Range Oven. Replaced ignitor.
Hi not that i can think of try google the range see if they have problem with this range
Feb 08, 2010 | Amana AGDS902SS Gas Kitchen Range
Kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
Jan 14, 2010 | Ovens
Oven won't come on
check the ignitor for the oven even it is glowing it may not be pulling enough amps to call for gas this is a very common problem with maytag and amana ranges replace the ignitor and it should work fine
Jul 12, 2009 | Amana RanARG7302 Gas Kitchen Range
Amana oven does not work.
the most likly problem is the bake ignitor is bad. this is a common part to fail in gas ovens. the bake ignitor part number for your model is 31940001, and price ranges from $45-$75. a bad clock can also cause this issue, but I would start with the ignitor. let me know if you have further questions. shane
Jun 29, 2009 | Amana ARGS7650SS Gas Kitchen Range
Viking pro. gas range/oven leaks when all knobs turned off
check both oven ignitor and broiler by turning the oven first, and time the time that the ignitor takes before the flame lights up, it should not take more then 60 to 70 seconds, and do the same to the broiler.the one that takes the longer passing that mark of the 70 seconds needs replacing it 's not getting hot enough to light the burner on time that's the one that passes gas with out igniting. replace that one.
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven won't lite
you have a bad ignitor. it may light up a little but it is not getting hot enough to light the gas. replace the ignitor
Nov 27, 2008 | Tappan TGF320 Gas Kitchen Range
Amana oven gas leak issue
staunch has no idea what he is talking about. It has nothing to do with the igniter, or it would fire up at all. Since you are saying that your oven does ignite and heat up, it is the internal gas valve that is the problem.
The way all recent (20 year at least) are designed, the gas valve internally can not open unless the igniter is working, for obvious reasons ... boom! The igniter circuit allows the gas valve to open, once it detects that the igniter is ready to "ignite" a gas flow. BUT, the valve can be bad in the AMOUNT of gas being delivered. Your's is allowing too much gas, more than can be burned, hence the smell.
DON'T use the oven until you have a qualitifed tech come out and replace the valve. It is very dangerous for you to do it yourself.
Nov 22, 2007 | Kitchen Ranges
Kitchen Ranges Logo
343 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
