Question about Car Audio & Video
My radio gets so hot around it.
Hi, i bought a radio for my chevy trailblazer '02; but around the radio gets so hot that i have to turn the AC on to cool it down. what the problem would be?
  • 3,267 Answers
Looks like some component of radio has a loose electrical contact(most probably the power cable) and its attachment points on the radio. Tighten all the electrical connection points visible & try to listen for any crackling or sparking noise coming from the radio and try to pinpoint it so now you know where something could be loose. Try to make sure all connectors are snug tight...sodeep
Posted on Jul 26, 2009
  • 24 Answers
You my have a leak in you vetalation system alowing hot air in behind the dash close all you Vents turn the Fan on take Your Hand and go around what Vents You can reach and see if You feel a Leak You can seal it with a Hi temp silicone if You find One
    Problem Solver:
  • 10 Answers
These cd players really get warm if it is getting hot from just useing the radio then the built in amp is over heating. do you have after market speakers on it?
Jump start trailblazer will run that day but next day it is dead there is a short some where
2006 Trailblazer won't start - Discussion on Topix
www.topix.com > Chevrolet TrailBlazer
Sep 6, 2012 - My 2006 Trailblazer will not start, bought a new battery, still will notstart, not even with a jump. ... i get a jump i drive it and charged the battery it seemed fine but then i went ... Then, next morning, when I turn key, all lights come on and radio... back a day and 360$ well that pos still will crank but will not start. 02 trailblazer a/c problem
Jul 21, 2011
2003 trailblazer key is stuck in ignition
Dec 21, 2009
2003 Chevy Trailblazer will not start
Jul 21, 2009
2002 trailblazers won't start
Aug 24, 2007
More results from www.topix.com
Oct 29, 2015 | 2005 Chevrolet TrailBlazer
Tip
How To Install Replace Fix Heater AC Fan Blower Motor Chevy Trailblazer 02-09...
How To Install Repair Replace Fix Heater AC Fan Blower Motor Chevy Trailblazer 02-09 1AAuto.com <utube src="7IWyOLDHJBM">
on May 25, 2011 | Chevrolet TrailBlazer Cars & Trucks
Why is hot air blowing from the vents when I turn on the ac in my 2003 chevy trailblazer
You are probably out of refrigerant / freon. You can take it to a mechanic or go to an auto store to buy refills. They sell the small canister with stem for regular joes to refill yourself, at a much lower cost than the mechanics.
Jul 29, 2014 | GM Carts 02 03 04 05 06 07 08 Chevy...
Where is the factory amp in a 2004 chevy trailblazer
I suggest you have the dealer look at this, you can't get parts for the AMP as GM doesn't sell them to the public just authorized repair shops
Jul 26, 2012 | Chevrolet TrailBlazer Cars & Trucks
2004 Chevy Trailblazer, At first you could only get the air conditioning to switch on by turnning the vehicle off and switching over to AC. Now the AC will not come on and it is always blowing hot air out...
Could be your main blower motor resistor, mine would still run the fan even after shutting off the vehicle.(safari van) Had to unplug the resistor to stop the fan,it was near the blower under the hood. Bought a new one for about $45 bucks. Replaced it and all is fine. Might want to check relays first, sometimes they stick and need replacing.
Good luck.
Dec 10, 2009 | 2004 Chevrolet TrailBlazer
AC blowing cool driver side and hot on passenger side
I have the same problem, mine resets itself when the key is turned off.must be a chevy thing.
Jul 22, 2009 | 2004 Chevrolet TrailBlazer
Chevy TrailBlazer heat won't shut off
most gm cars use electrily controled temp actuator door on top of center of heater case . if move the temp lever to hot or cold you should see the door arm move sometimes the arm will move but the door dosent there is three wires too the motor one 12 volt one ground and one return to the hvac modle head controls there are different colors for the return wire.basically you can un hook the arm and move it manunlly to see if it makes a difference at the vent while the ac system is on.the way test for the problem is to check the voltage on the return wire at the motor and ground with a dvm meter you should see a vary voltage when slide temp controls from hot to cold . more than likey it is hvac control head but check first they are costly.
May 29, 2009 | 2002 Chevrolet TrailBlazer
Car Audio & Video Logo
105 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
