Question about HP Photosmart 2610 All-In-One InkJet Printer
My 2610 All-In-One printer will not read photo memory cards of 4GB or greater. Can this be fixed?
This printer model is only support the maximum size of memory card of 1 GB.
Posted on Sep 14, 2009
It wont read the cards
A: Make sure you're using a supported memory card. See the table below for specifications:
Memory Card Type Maximum Capacity CompactFlash Card
(Type I and Type II--3.3V only) 8GB Microdrive (3.3V only) 4GB SD (Secure Digital) 2GB MultiMediaCard 1GB
If you connect a compatible CompactFlash (CF) adapter that can read 8GB memory cards, you can also use the memory cards listed below (with a capacity up to 8GB):
  • Memory Stick
  • Memory Stick Duo
  • Memory Stick PRO
  • Memory Stick PRO Duo
  • xD-Picture Card
  • SmartMedia Card (3.3V only)
Mar 26, 2014 | Epson PictureMate Photo Printer
I want recover my photos in my 4GB SDHC Sandisk Memory Card
click start control panel administrative tools computer management disk management right click on your 4gb drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
i found best results tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
May 07, 2012 | SanDisk 4GB Secure Digital High Capacity...
EPSON PICTUREMATE PRINTER WILL NOT ACCEPT 4GB
Here is a quote from the Epson website.
"These products were developed and released at a time when large capacity cards such as 2GB or 4GB SD cards were not commercially available or widely available. Therefore the printer and its memory card reader do not recognise larger capacity memory cards."
So you're stuck with it I'm afraid.
Mar 31, 2010 | Epson PictureMate 500 InkJet Photo Printer
I have a PNY Optima HD memory card and it will not read in my HP photo printer. Is there any way to fix this?
You don't specify your printer model. Check in your printer's specifications (either in the manual or online) if your printer is compatible with SDHC cards.
SDHC is a new generation of SD cards and older devices might not be compatible with this it.
Nov 27, 2009 | PNY 4GB Secure Digital High Capacity...
My smaller memory cards work, but my 4gb card says media error in my brother printer/scanner when I put it into the usb port (photo capture). Tried it dozens of time, doesn't work, but I was able to read...
Many older system will only support standard SD cards up to 2GB and HD SD cards will go above 2GB. It is a limitation of the printer and not an error with the card.
Nov 21, 2009 | SanDisk 2GB microSD Memory Card
Memory card error for 4GB SDHC card on HP Photosmart printer 2710
Well SD max is 2gb, so you can get 2gb if you want.
SDHC max is 32gb. If you are not on a budget, try upgrading your printer to a newer model.
SDHC is coming out with even newer models, now with a class 10 (10mb read/write speed - but very costly).
However, if it doesn't matter to you, might as well just stick with the same printer, since SD cards are coming down in price. Just make sure you get 2gb cards with a good class speed.
Sep 10, 2009 | HP Photosmart 2710 All-In-One InkJet...
MEMORY CARD ERROR
What photo printer are you using?
It might not be able to read the High Capacity Memory Card. Check the user manual it should say what size and type of memory cards it is compatible with.
Aug 04, 2009 | PNY 4GB Secure Digital High Capacity...
Hp photosmart 2610 won't read my sandisk ultra memory card
Previous solution is the FAIL. Original poster says it works fine in _camera_, but not in _printer_. _Printer_ is the compatibility issue, not camera.
Feb 03, 2009 | HP Photosmart 2610 All-In-One InkJet...
EPSON RX600 PRINTER
Below is a chart of memory card capacities that have been tested by Epson. Testing was done before the products were released.
Please use this chart as a general guide line.
MEMORY CARD TYPE MAXIMUM CAPACITY TESTED
Compact Flash 4 GB
Secure Digital 1 GB
Sony Memory Stick 1 GB
MagicGate Memory Stick 128 MB
xD Picture Card 512 MB
Smart Media 128 MB
Any size of card other than that which is indicated above may work, but is not supported or guaranteed.
sorry for this one :(
Apr 18, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
HP Photosmart 2610 error message
Turn off your printer. Look in My Computer for any HP Memory card icons. Right-click on them and disconnect all that you see.
Mar 19, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Photosmart 2610 All-In-One InkJet Printer Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
