NAD 3020a crackle in right channel regardless of volume.
I have a NAD 3020a, there is a crackle that comes out of the right channel (i have checked by swapping the speakers and it isnt the speakers) The crackle happens all the time regardless of the volume of the amp, even if the amps volume is on lowest and there is nothing playing through it, the crackle will be the same as the opposite situation. any ideas what could be wrong with the amp, would it be something i could fix myself? Thankyou
  • 24 Answers
More than likely you have a bad transisitor on that side and the frequincey is distorted there's not much you can do except take it back if it's new or take it apart and check for the bad part but if you do that you had better know what your doing!! it may be just 12 volts but thru an amp it's a nasty shock
Posted on Jul 26, 2009
Left speaker not working, system crackles if left side is active, alright when left side shut down.
Get a meter and check the resistance on the speaker. Looks like a speaker may be blown but with the description of the crackle noise from the slide controls you might have a bad pot in the unit or the pot has come loose from the board. This could explain why the speaker blew out
Jul 30, 2015 | Behringer Europort EPA150 Ultra-Compact...
My Technics SUV 660 is making a crackling and popping sound regardless of where the volume is. It does reduce once the amp has been on for an hr or so. Also the speakers are not consistantly on. Any a
If the sound is on both channels then it's probably a device that is connected to both channels. I don't think it's the power supply. I rather suspect it's in the power amp section, since it's not affected by turning up the volume. If the amp uses one of those STK devices as a power amp, it could even be that.
Image of an STK power amp below:
Feb 17, 2014 | Audio Players & Recorders
Hi, I get very intermittent hissing/crackling from the left channel of my NAD C370. I've replaced the speaker wire and the wire that I'm using for bridges on my AE Evo 3 speakers which seems to have...
Could be caused by a burnt resistor in the channel of the main power amp. You should be able to see it. It might have been caused by the faulty speaker wires.
Oct 07, 2017 | Audio Players & Recorders
Could you please let me downloading the schematic for NAD 3020A integrated amplifier
Please elaborate your problem providing us with more details of the problem.
Thanks for using FixYa.
Jun 30, 2010 | NAD Audio Players & Recorders
Hi, I have a second hand NAD 3240PE amplifier, the right channel has an intermitent crackle but the left channel is fine, Any ideas as to what might be causing this problem?
Crackling is usually a dirty control. Try using an electronics cleaner (with lubricant) and spray out all of the controls and switches. With the unit off, work the controls and switches back and forth to "spread" the lubricant. I would spray, work and spray again.
Update this with the results and also see if the crackling is related to the overall volume level. If tied to the volume level, there could be a transistor inside that is breaking down and causing distortion.
Dan
Dec 28, 2009 | NAD Audio Players & Recorders
Very loud hummimg and crackling - even when volume turned down.
There are a few variants for this model depending upon the serial number. From your description, there are some capacitors in between the amp stages called coupling caps that are failing. The hum is some DC current being passed through the output stage. The crackling is probably just dirty controls.
Dan
Aug 18, 2009 | NAD Audio Players & Recorders
Need user manual for setup of the amplifier.
It should say next to the speaker terminals what impedance of speaker the amplifier is rated for. You can drive any speaker within reason with just about any amplifier as long as you are not trying to attain loud levels. Here is a link to the service manual for your amplfier. It states in the schematic power ratings for 2,4, and 8 ohm speakers so you can assume that this amplifier is compatible with those impedance speakers. NAD is generally known for their beefy amplifier sections. http://www.scribd.com/doc/7234868/NAD-3020-Service-Manual
May 03, 2009 | NAD C325BEE Amplifier
Sound through one channel
Only the right channel had a sound,the left channel is mute, whatever adjustment you did and whatever balancing you done nothigs happen,even you interchange the speakers. The problem is in the power amp. The STK IC there is busted already, it's better to change it with a new one so the performance become normal again.
Jun 14, 2008 | NAD C372 Amplifier
Output volume has dropped in right channel
dear sir,pls check the HT voltage fuse, LTsupplay also and out put stage,and volume controle,
Jan 17, 2007 | NAD C350 2-Channel Amplifier
666 people viewed this question
 Grubhead
Grubhead
