SOURCE: Clean cycle in oven doesn't work: FO EO
Oliversmom, Im not coming up with any information on the model number posted. However on the kitchenaid the F0 E0 is default for no error. Press the cancel button to put the range in idle state. Then in this order press cancel-cancel-start. See if an error code comes up different from the F0 E0. The F0 is what is throwing this whole deal off. If it was F1, F2, F3 etc...it would make more sense. See if you have a complete model number you can post along with the error code after doing the above key dance. We'll see if we can solve the issue....Catriver..post back.
SOURCE: oven section not working
beaver, the F5-E5 is the code for self clean temp not achieved after 30 minutes. This makes sense since you are having trouble pre-heating your oven on regular bake. I believe your ignitor is not drawing enough amps to open the gas valve all the way. Sometimes these can be erratic, work sometimes, sometimes won't. Your part number for the oven ignitor is 9782065. Catriver..post back.
SOURCE: gas stove /electric starter won't click to start cleaned stove
Try cleaning the starter with rubbing alcohol and toothbrush. There might be soap or boiled over residue on the starter. If that doesn't work, try using fine 150 grit sandpaper and gentle clean the starter with it. This problems drove me nuts too. Good luck!
SOURCE: After using the self-clean cycle, display panel went black and oven door stayed locked.
Happens alot dont feel bad , self clean mode runs the elements at 500 deg. to cook off everything possible , what happens is the cabinet gets to hot and heats saftey temp. fuses until they go out and they are not resetable. they are always located in different areas of ranges but usaully in the back. you can ohm them out to check them if you have a meter.let me know if you have any other questions.
Phil
SOURCE: self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
