Question about Yamaha RX-V520
Rxv-520 my receiver overheated and shut down fuses are good.what should i check next?
    Problem Solver:
  • 9 Answers
Hello, it is worth checking that there is adequate ventillation around the unit, especially if it is in a cabinet. Also check that there is no dust clogging the vents on the unit. Another cause for overheating is using speakers that require far more power than your receiver can provide, or speakers with an ohm rating that is lower than the amplifier provides. Also, check to see if any wires to the speakers are crossing over as shorting will cause the amplifier to overheat and cut out. Hope this helps.
Posted on Aug 01, 2009
GE spacemaker electric dryer PCKS443EBWW. Dryer shuts off mid cycle on timed dry setting. Wait till cool down and will start again. Venting is clear, I vacuumed inside and around motor. Any ideas?!
Mark, Could be limit /over heat/thermal fuse/switch, check or have checked by a good repair Tech., diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What to Check when your Dryer Shuts Off Mid Cycle
Whirlpool Maytag Dryer Diagnostic Shuts off mid cycle not heating...
Kenmore Whirlpool Clothes Dryer Repair The Most Common Problem
GE electric dryer overheating shutting down
Jul 10, 2016 | GE Dryers
I have a Sony AV model str-dh520. The protection circuit keeps coming on then shuts down. I tried unplugging all the speakers from the unit but still protection circuit is still activated and shuts down....
Hello there friend,
Go here at Sony for some ideas to try when PROTECT shows on your machine. https://us.en.kb.sony.com/app/answers/detail/a_id/39211/c/65,66/p/41901,43145,92877,44396/
It seems the main amplifier chip / circuit may be overheated or short circuited and is now permanently faulty and need replacing Generally means desoldering the chip and replacing.
Sep 08, 2014 | Audio Players & Recorders
I tried hooking up an old polk sub to my yamaha rx-v659 av receiver. smelled wires burning smell. before i could unplug it, receiver shut down. now it will power up for about 5 seconds and shut off. manual...
If a fuse was blown, it likely would have no power. However if the power board has overheated, the capacitors may have swelled up and burnt out and will only allow it to power on for a few seconds, then shut down. The capacitors can look swelled up or burnt or have burn marks on the power circuit board. You can test them with a continuity meter. Each component has a printed number of it's voltage and ohm resistance so you can test them.
Jul 26, 2010 | Yamaha RX-V661 Receiver
The receiver is not turning on. Try all possible solutions ie;Power cord. What is cicurity protection and how do I check for that or correct?
Circuitry protection means the unit is overheating so a fuse blows and shuts down the power to save the electrical components.  You need to find the fuse and replace it.
Oct 25, 2009 | Yamaha HTR-5890 Receiver
My Tchnics Sa-Da10 shuts down on what appears to
Ahh technics. Technics always had overheating problems, trust me. Every since they started, their amps would get so hot they would hurt to touch. The reason the fan is not coming on seams to be something inside the circuit board. I'm sure that technics could fix this. If the fan works out of the receiver, then it must not be the fan. ;P
I would maybe get a computer fan, and just put it on top of the receiver and turn it on, or send it in for fixing. Also, do you have to crank the volume to get the speakers to play at your volume, and does the impeadence match the receiver. Because you may be pushing the receiver too hard.
Oct 11, 2009 | Technics SA-DA10 Receiver
HTR-5280 Receiver Fuse Blown
the fuse rating should be printed at the back near the fuse holder itself. If it opens the fuse again and again probably you have a circuit loading problem in the receiver...either one of the amps is failing.
Aug 10, 2009 | Yamaha HTR-5280 Receiver
Works for a while, then shuts down. May or may not come back on the next day..
Check all cable connections as one may be loose & causing intermittent power loss. Another thing to check is your fans. An overheating cpu will also shut down your machine to protect it from damage. Make sure your fans are clean & spinning; if not replace with compatible fans. Check your heatsink to make sure it has a good connection & has thermal paste properly applied. Hope these help.
Jul 02, 2009 | MSI MS-6734-10 (-6734-010) Motherboard
Denon AVR-1803 keeps shutting down
check your speaker wires make sure none are touching each other this will cause a short and shut the reciever down
Mar 17, 2009 | Denon AVR-1803 Receiver
My sx-315 pioneer receiver overheated and shut down.
Probably the thermal fuse in the main power transformer. Check for ac on both the primary and secondary of the transformer. If you have 120v ac on the primary when the standby light is off and nothing on the secondary you need a new transformer.
Feb 08, 2009 | Pioneer SX-315
Haron Kardon 3375 Recevier Shut Down Problems
5 amp "slow blow" fuse where power cord connects to amplifier has probably blown. 9 screws holds the cover on, remove them and check fuse.
Dec 10, 2006 | Harman Kardon HK 3375 Receiver
Yamaha RX-V520 Logo
185 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
