Zeki Tablet Freeze on boot, di the reset with the pin does nothing. power + , factory reset does not work. Can I reinstall the JellyBean OS for a Zeki TBDG1073B FID:KH and where can I download it
on Zeki Tablet you had to hold both the "Reset" button and the "volume up" button at the same time for about 15-20 seconds it than boots into Safe Mode which you can select a full factory reset. NOT VOLUME DOWN.
If this fails, 1 888 999 4215 is Zeki support. If in warranty, tell them of failure of factory reset. They may request it be sent to them.
reset it using the pin hole reset button on back
or You can try a factory reset on the tablet. Hold the volume down button and press the power button. This should bring up a system menu that should have an option to perform a factory reset on the tablet.
Go to this site for the instructions on how to do a hard reset on your tablet.
http://www.howtogeek.com/130611/how-to-factory-reset-your-android-phone-or-tablet-when-it-wont-boot/
You can try a factory restore, but if that doesn't work you will need to buy a new tablet. These cheap tablets are throw-aways unfortunately. Note that a factory restore will erase any files you have on the device.
Factory Restore on Android devices:
- Turn off the device
- Hold Volume Down and also press the Power button until a menu comes up
- Use the Volume Up and Down buttons to select Factory Reset (or Restore)
- Press Power to select
Hello there,
From the Zeki website it says do this.
If you have set the screen lock to a password or pin code, and have forgotten the code; you will need to reset you tablet to factory default setting.
Make sure your tablet has a full charge
Press and hold the Volume - button and tap the Reset button
(The reset button is located between the HDMI and USB ports)
Continue holding the Volume - button until the boot screen appears
Release the Volume - button
Use the volume controls to navigate to "Wipe data/Factory reset"
Press the power button to select
Navigate to "Delete all user date"
Your table will take several minutes to reboot to a factory default setting.
I'm assuming it is the Zeki 8" TBDG874B. What I would do to get it of the flashy Android logo is hold down the volume button on the minus (-) side and get a small pin or needle to tap the reset. While holding the volume it will reset, then tap the power button still holding volume it will bring up a list. Do a factory reset (you lose all data but that's what I would to do to be on the safe side).
I don't know which OS your tablet uses... perhaps Jelly Bean. If so, if you push the Power button and the "Power Off" option shows up on the screen press the selection of "Power Off" and hold your finger down on it until a pop-up screen shows a selection of: Boot into "Safe Mode". Choose that and what happens is it boots up with no applications loaded. You should then be able to access the "Settings" and then choose "Factory Data Reset" option. Hope this works
