Question about Whirlpool Dryers
MY WHIRLPOOL DRYER MOD.#GGW9250PW1 DOES NOT START WRINKLE GUARD LIGHT STAYS ON AND SO DOES MORE DRYNESS LEVEL LIGHT
  • donshirlee Jul 26, 2009
    WHICH CONTROL BOARD WOULD IT BE? I SEE THE ONE IN FRONT OF DRYER AND THERE IS ALSO ONE UNDER TOP COVER ON LEFT SIDE. SOMETIMES WHEN DRYER DID START IT WOULD GO OFF AFTER 2OR3 MINUTES OR MAYBE RUN PERFECT. DOES THAT POINT US IN ANOTHER DIRECTION?
    WHERE IS THE DRYNESS SENSOR LOCATED
  • Whirlpool Master
  • 19,396 Answers
First try unplugging the power cord or tripping the circuit breaker for five minutes.
If that does not clear the error, then the dryness sensor, or the control board may be damaged. In that case parts must be tested and eventually replaced after doing a diagnostic procedure to check if there are stored fault codes on the appliance.
Posted on Jul 26, 2009
  • Ginko
    Ginko Jul 26, 2009
    You need to check for stored error codes.
    To enter the diagnostic mode,
    choose any selector button other than Pause/Cancel and do this keyboard sequence:
    Press and hold for three seconds,
    release for three seconds;
    press and hold for three seconds,
    press and hold for three seconds.
    If you did it correctly all the indicators on the console will light up for five seconds and you’ll see the code “88” in the Estimated Time Remaining display.
    If there are no fault codes stored in the board, then all the
    indicators will momentarily turn off, then come back on and stay on;
    the “88” will remain in the digital display.
    When there are fault codes stored in the system, the most recent will flash (eg.F01).
    Here code table:
    If there is F-01, then replace control board.
    If there is F-28 or F-29, replace moisture sensor.
    Parts and diagrams here.
    Regards.
How do I turn on bell on my dryer
From the Whirlpool user manual:
(OPTIONAL) Your dryer may have an End Of Cycle Signal. The
signal is helpful when drying items that should be removed
from the dryer as soon as it stops.
On some models, the End of Cycle Signal is fixed.
On other models, the End of Cycle signal is part of the
Start button and is selectable. Turn the PUSH TO START
button to ON or OFF. The signal will sound only if the
selector is set to On.
Jan 22, 2016 | Dryers
Dryer shuts off within a few seconds and smell burning
That's a sign your motor is bad. Soon it won't start at all.
Mar 13, 2014 | Maytag MEDC300XW - 29", 7.0 Cu Ft, He...
Dryer keep going on by it self
Some of them have wrinkle guard. They keep going till you shut it off.
May 16, 2013 | Kenmore Dryers
Dryer cuts on run a minute starts buzzing loudly and shuts off then a little while later starts by its self
DOES THIS DRYER HAVE A WRINKLE GUARD CYCLE OR SWITCH THEN THIS IS NORMAL ASLONG YOUR IN A WRINKLE GUARD CYCLE ON TIMER OR WRINKLE GUARD SWITCH IS ON
Jan 26, 2011 | KitchenAid Dryers
My dryer WED5820SWD wont stay running unless I hold in the start switch. It happened the other day in the middle of the cycle, also the wrinkle guard stoped working as well. I think that it is the timmer?
Sounds like you have a bad door switch, if it wont stay running and reason for the wrinkle guard not working is the electronic control (circut board) is bad.
Aug 05, 2010 | Whirlpool WED5800S Electric Dryer
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
Kenmore elite dryer - how do I turn on the wrinkle guard? if the light is steady - is that on? is the light for the wrinkle guard or the damp dry cycle. Why does the static guard light flash?
Head over to the manufacture's website.
www.searspartsdirect.com
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 16, 2010 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
Dryers Logo
138 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
