Question about Kitchen Ranges
Anything i cook on this grill turns black quickly not burnt just black.i have tried cleaning grill to no avail.i bought this grill at an estate sale and it wasn't put togeather yet.don't know what to do
  • alana116 Jul 26, 2009
    thgis grill is at my campsite and i will go out
    this afternoon and get the info for you
    thanks
    its a sunbeam 54s thats all i could find on it.i even changed the propane tank and everything i cook still comes with a black on it ,you can see the black smoke .
  • Kitchen Ranges Master
  • 5,660 Answers
I need to know the grille name and model number, to possibly give advice for it. From your description so far, it sounds like the heat range is too far up, therefore cooking the outside of the meat at a great rate. If you are a person who likes blackened meat, this would be the grille, and setting for you! Obviously it isn't. I await the name and model number. I'm going to see if there is an adjustment, and will give you direct links to my findings, plus answer any questions you have to the best of my ability.
Posted on Jul 26, 2009
  • joecoolvette
    joecoolvette Jul 27, 2009
    There is no adjustment that I can find. It's a simple apparatus that is used to mix air with the propane.
    It is because of this that I believe there is blockage in the burner orifices, and/or the burner tube, or tubes.
    (Actual name of each tube is Venturi)
    Allow me to explain the construction of the burner mechanism, and what I'm referring to in the above statements. To do this, I need to give you a link to a website, that sells parts for your sunbeam Model WG541HPB9 (Sunbeam 54S) It is not a link to advertise this website, it's just to show you the construction.
    http://www.appliancefactoryparts.com/gas...
    On the exploded drawing of your barbecue unit you can enlarge it, by Left-clicking once. Then on this page, the illustration can be enlarged one more time, by clicking on it. The scroll bar on the right allows you to move the view up, or down. (Not trying to insult your intelligence)
    In this illustration the burner unit is item number 43. The burner 'tubes', (Venturi) are item number 44.
    I refer to the Venturi's as tubes, because my thinking is that Tube is easier to relate to.
    With the grates removed you should be able to get a clear view of the burner unit. As you can see it is an oval shaped metal piece, with holes going around the outside edge. These holes are Orifices.
    I'm curious if the previous owner spilled something that has burned, and is now clogging these orifices. Granted, this would cause less heat, but it would also cause the burner to not function properly.
    The burner is not getting enough air to burn properly. This is the black smoke you see.
    I believe the main cause to be that something is blocking those venturi tubes. This is where the main mixing goes on for the air, and propane. Perhaps a mud dauber wasp, has left mud mixed with it's larvae in there. They seem to like holes like this tube.
    Also take a look at the Collector Plate. Item number 46. (Plate collector ss 98) If you click on -> More info, that's in blue, it give a better illustration. See if the two slanted slots, shown at the top, are clear, and free of any blockage.
    I await your findings.
    joecoolsvette
We bought at an estate sale. We are looking for a manual
Try using the make and model and the word "manual" on a Google search.
Nov 27, 2015 | Grilling
Changed gas grill burner, now everything cooked is black on outside
1) Sounds like you may have a smoking issue. Find the cause of the smoke and it should resolve the blackness issue.
2) Is everything clean? if not clean grill and if you have cover over burner under grill clean that as well.
Aug 05, 2011 | Fiesta 240 Grill
It takes a very long time to cook anything on the weber grill. it never gets really hot. The grill is about six years old. What do I do to correct this problem?
check for rust/debris on the nozzles (these are small screws with single hole in them inside of the burner, clean the burner, dissassembly and clean the valves on the grill NOT ON THE BOTTLE!
this should solve the problem, alternatively, if burner was not used for long time, regulator maybe stuck in this position and will need replacement.
Jul 15, 2010 | Weber Genesis Silver A Grill
It will not turn on - just bought this as a new product at an estate sale
caveat emptor
there is usually a cooling off period on these types of sales. return it! most estate sales suggest testing before bidding or give statemnt that it has been checked. contact selling agent
Please rate my help++++Thanks for using FIXYA
Jun 25, 2010 | Bravetti Quad Blade Food Processor
I just bought a gas grill and there is a big sticker in the inside of the top of the lid im havin a hard time getting that sticker off want to know the best way to do that
There is a rpoduct calle GOO GONE that will remove anything...
But...
If it was me I would just turn the gas grill to hi fire "CLEAN" mode and burn it off. This will clean and santitze the new grill at the same time also..
Heatman101
Mar 05, 2010 | Uniflame FG2204C Grill
Estate gas dryer heats up but then flame goes out after around 30 seconds. Replaced the gas valve coils and the thermal fuse, but problem continues
It's likely the problem with the airflow. High limit thermostat is turning the gas valve off. Clean/replace the vent and lint trap.Check if there is anything stuck to the grille inside the dryer.
Oct 13, 2009 | Estate TGDS840JQ Gas Dryer
Just bought a grill to go at a yard sale . Can you cook with the lid down or does it have to be up when cooking?
Yes you can cook with it down. It will get hotter being down so you may have to adjust the heat lower.
Jul 11, 2009 | Thermos Grill2Go Gas Grill 4656110
Rice cooker
To practice, add i cup of rice to cooker, and then 2 cups of water (water should cover the rice 2 times over. You can add salt if you wish, then turn the cooker on and when it goes off, it is done.
Nov 04, 2008 | Kitchen Appliances - Others
HOW LONG DO I OOK HAMBURGER PATTIES USING THE GEORGE FOREMAN GRILLING MACHINE
I can do better than that here you go look at this.What have I personally prepared on my George Foreman grill?
Steaks
Hamburgers
Hot Dogs
Boneless Pork Loins
Country Style Ribs
Boneless Chicken Breast
Bone in Chicken Thighs
Bone in Chicken Breasts
Chicken Legs
Grilled Ham and Cheese Sandwhiches
Italian Sausage along with Green Peppers and Onions
This unit has a floating hinge which allows me to cook thicker cuts of meat and they cook evenly.
I even use it to reheat the meat leftover from the day before, it heats them quickly and sears in the flavor without drying the meat out. I prefer reheating with my grill over microwaving.
One day last summer I was in the middle of cooking BBQ Chicken on my Charcoal Grill. We were having a family outing and out of the clear blue sky it just started to rain... Well I had no choice but to finish cooking all the chicken i had started on my handy little George Foreman grill. This took a little time because the amounts of chicken I had on the grill and could only fit just a few pieces at a time. but it was a lifesaver... saved our picnic. Which gave me the idea to precook the chicken on my George Foreman Grill then finish cooking it over Charcoal. I found using this method takes alot of time away from having to stand by the grill basting and turning. All in all, to me it seems that within 30 mins the Chicken is fully cooked compared to anywhere from 45 minutes to an hour and your still guessing and cutting into the meat to see if its done.
The Champ also supplies you with some of his famous grilling recipes which I have not yet tried because I have my own way of seasoning my foods. Although they sound delicious!
Here are some examples of his suggested Cooking Chart for this Grill: Cooked Medium (160 F) to give you an Idea as to how quickly it does cook.
Salmon Filet 3 minutes
Salmon Steaks 6 minutes
White Fish 5 minutes
8 oz Turkey burgers 6 minutes
8 oz Hamburgers 9 minutes
Chicken Breasts 9 minutes
NY Strip Steak 7 minutes
Pork loins 5 minutes
Is there anything you found you didnt like?
Yes,one thing I must admit is I do not like is the fact it does not have a shut off switch.
I've learned that if you wait until the light on the unit is OFF then you are less likely to see a SPARK when you unplug the unit after use.
Back to the Positive and another important fact. Time to clean up is really a Breeze. I allow it to cool then I use the plastic spatula to scrap away any excess fat or food then I wipe with a damp paper towel. Toss away paper towel full of grease and grime and go over it a clean damp cloth, wash the tray and spatula and its ready to be put away.
Looking for Information about this grill or other George Foreman Indoor Grills check out http://www.eSalton.com.
good luck and my motto is try it you have everything to gain and nothing to lose.
Jul 11, 2008 | George Foreman GR10AWHT Indoor Grill
Removing face of DeLonghi AR1070
This is a two slice Delonghi toaster, model CT12 and is has stopped heating on the right side
Jun 14, 2008 | DeLonghi AR1070 Retro 1500 Watts Toaster...
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
