Question about Hannstar I-Inc TW-191D Monitor
Hi, my TW-191 suddenly quit working yesterday. . . it is only 2 years old? When the PC is first turned on the amber light turns green and the screen is displayed then after a few seconds goes blank. Through various trial and error checks I've discovered the when I disconnect the VGA cable and reconnect it the screen will reappear again for a few seconds before going black??? Is the monitor toast? BTW, I've tested my PC with a spare monitor and it works fine.
  • ottsrx7 Jul 26, 2009
    Thanks for the info. . . I pulled the boards out and closely inspected both of them. I did not see any signs of leakage or popped capacitors? What would the next step be?
    Thanks,
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 26, 2009
  • Buddy Mcsparrin Jul 27, 2009
    Can you take a few pictures of the boards in the monitor and send them to tech@ccl-la.com I will check them and see if they cross to any other manufacturer and look for a solution for you.
    Buddy
    Corporate Computer
Mini crosser typ M1 stopped working whilst being used. Batteries test out OK. When power is turned on the following lights flash:- 2 red, 4 amber, 4 green. Scooter is about a year old, had little use...
the standard error code you describe list this:
"Over voltage detected. This can happen with a bad battery connection although unlikely. More likely your battery charger is faulty and is overcharging your batteries quite severely."
so i would check this out first.
Aug 24, 2013 | Health & Beauty
It had been quite a while since I turn on my compaq presario 7204APr. And when it turned it on, there is no image appear on my monitor screen. How can I fix it?
Desktop PCs have separate power buttons for the monitor and the desktop component.
1. Make sure both items are turned on.
2. Make sure the cable from the Computer to the monitor is connected securely.
3. Are there lights on the monitor? Are they Green?
If they are amber the connection is not solid or the Video Card is bad.
Are there lights on the desktop PC? Are they blinking? If so the PC is working and the video is not. Check the connections and monitor power.
4. When you turn on the PC do you hear noise? If yes, the PC is working.
Beeps will sound if the video, memory or keyboard is not working.
After you check these things, reply to let us know if it is working or not.
-PCTechsOnline
Sep 10, 2010 | Compaq Presario 7000Z PC Desktop
I have a DW027A drive. It is about two years old. I use NovaBackupServer software to run the backups. My backups started aborting suddenly. I get an error message that suggests there is no free space on...
Try manually expiring the media and rery the job. We can dig in more if you can clarify more on what the amber light is for..
Please come back and rate for me if this solution turns to be helpful for you.
Thnx :)
Mar 15, 2010 | HP Computers & Internet
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
There is no display on the monitor screen. The amber light on the power switch keeps blinking uselessly!
The monitor requires service The monitor is not receiving a signal from the computer
Apr 15, 2009 | Computers & Internet
TV wont turn on.
Hi
This case needs to diagnose by a qualified technician
Thanks
Nov 28, 2008 | Mitsubishi Televison & Video
Charging the battery the amber light comes on, but then after a while the amber light flashes. Does this mean the battery is charged? It used to turn to green with the battery that came with my...
if it turns green that means that it is charged, but it then if it turns amber that means that it is going bad
thanks
hope this works for you
Aug 27, 2008 | Acer Computers & Internet
Hannstar I-Inc TW-191D Monitor Logo
849 people viewed this question
Top Hannstar Computers & Internet Experts
 Russ Hill
Russ Hill
memman
memman
Level 1 Expert
Are you a Hannstar Computer and Internet Expert? Answer questions, earn points and help others
