Question about Garden
How do i remove left rear wheel to replace tire on craftman riding mower model 917272140
  • 123 Answers
First Raise the mower and set the draw bar on a block or jackstand or something. Now pull off the black plastic cap it might be harden from age so pliers will help here. Now take a screw driver and stick it in that small grove in that E-clip and turn the handle to prize off the E-clip. Now remove the large washer there may be two. Pull and rock that tire back and forth there is a steel keyway in the axle. It all could be rusty so spray it with oil and use a hammer on the back side if needed.
Posted on Sep 01, 2009
How do i remove the rear wheel on a Scott's s2046 riding mower?
you will probably have to heat it up with a torch to get it off take a dead blow hammer and hit the back side of tire go al arond it also use wd 40 spray on it keep using torch to heat up and beating the tire it will eventully come off
Sep 12, 2014 | Garden
Removing right rear wheel husky riding mower
remove bolts from desired wheel wiggle tire to loosen bearing from race remove bearing slide wheel from axle make sure you keep straight as not to damage grease seal on inside of tire
Sep 13, 2013 | Garden
Mtd removing rear wheels from axel
Be very carefull, if you pull the wheels hard enough the half shaft will pop the circlip on the inside of the gearbox and come away with the wheel, this will then require a gearbox strip down, leave it soaking in penetrating oil and try again.
Jul 11, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
Dynamark / Noma riding mower Mod# A38120910, SER# 149606, Code 0025M. how to get rear tires off?
i change the tires with the wheel on the mower if they don't slide off with the bolt or clip removed
Jul 02, 2012 | Garden
Changed the tire on my craftman lawn mower and now it will not drive
there is a key keeping the wheel and axle in sync. make sure this did not fall to the ground when you removed the wheel. fits in the slot on axle and wheel. if you lost it you can buy another at a small engine parts store. another possible problem is that you slid the wheel on backwards and it is rubbing against the mower frame.
Aug 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a roper riding mower that needs a new rear tire, the wheel has no lug nuts, is there some kind of trick to release the wheel?
The wheels are not designed for easy removal. You have to pop off the hub cap, remove a retaining ring (which is easier with a special tool), and then pull off the wheel (which may require a special puller tool). So don't do it. Jack up the tractor and you can remove and replace a tire on the rim without taking the wheel off.
Good luck! If this is helpful, please rate my answer, thanks!
Jun 10, 2010 | Garden
How do you remove front or rear wheel on craftman riding mower.model #917.270921
You should find little clips holding them in place. Take a screwdriver and find where the hoop (clip) has a notch in it and put pressure against it...it should pop out (wear eye safety gear). Once clip is off....tire will pull off www.nnyparts.com
May 27, 2010 | Craftsman Garden
How do I remove the square key from the left rear tire of my Craftsman riding mower model #917270410. I am unable to get any type of vice grips or needle nose on it? Is a wheel puller required to remove...
In theory, the wheel simply slides off after removng the retainer.
If yours won't shift after soaking in WD40 or similar, you will need some sort of puller.
Some craftsman wheels have holes drilled in them for this purpose. If yours don't, you will need to drill some.
DO NOT attempt to hammer the wheel off. You might get away with it, but there is a fair chance that the axle shaft will come out of the transmission. If that happens, the transmission will need to be removed and completely torn down to fix.
If it really won't shift, destroy the wheel and cut it off. It's a pain, but cheaper than a new trans. You can (just about) get the tire off with the wheel still on the tractor.
Use copper-based grease on the axle when re-fitting, to prevent it happening again. I always remove the wheels once a year - just to ensure that I can if I need to!
May 09, 2010 | Garden
Rear wheel removal from craftman riding mower
Do you have the rim and tire off and you want to remove the hub?
I believe every rider mower and tractor I've had and worked on had the rear tire attached to the hub as in a car, with lug nuts or lug bolts. Check to see if there are four or five lug bolts that hold the rim onto the hub.
Jul 29, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
339 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
