The freezer is not terribly cold, things are defrosting and panel keeps alarming.
SOURCE: kenmore sideby side fridge
You have a defrost system problem. Defrost is controlled by a timer which energizes the heater circuit. The heater circuit has a radiant or cal rod type heater which melts the frost from the coil. When the coil reaches a temperature where all ice would be gone a termination switch opens and shuts of the heater. The timer will continue to run until defrost time expires (18-22 minutes).
If you can locate the timer there is a clutch head screw to advance the timer to the defrost position. Turn the screw clockwise SLOWLY until you hear one audible click. The heaters should come on and defrost take place. If the unit restarts after the 18-22 minute period the timer is good, if it does not restart advance the screw to a second audible click and it will restart.
If you had to turn the timer the to second click to get it started cooling replace the timer.
If the unit restarted after the 18-22 minutes and defrost did not happen your problem is in the heater circuit. This would be an open heater or bad defrost terminator switch. To access the heater and defrost terminator the back panel in the freezer section must be removed. With an Ohm meter you can check the heater to see if it is good.
SOURCE: Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
SOURCE: Westinghouse fridge freezer alarms keep going off
Try a different web site, where are the solutions on this one????? Great site..... not
SOURCE: whirlpool side by side fridge
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted.
the temp display on freezer shows - - flashing
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check
Refrigerator
not Cooling
Timer Problem
Water
from Freezer
Refrigerator
heatman101
