Cell Phones Logo
Toni Wright Posted on Jun 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I bought a galaxy on 5 it has no sims card and says it has alerted that someone tried to reset the phone to factory without approval. I bought it from an individual, should I be concerned it is stolen
matt
Level 3:
  • Galaxy Master 1,666 Answers
  • Posted on Jun 21, 2017
matt
Galaxy Master
Level 3:
Answers
1666
Questions
Helped
696334
Points
9998
Yol need the user id ect to bypass or it is lost/stolen
I did a factory hard reset on my Samsung galaxy s6 and now I get either "couldn't sign in there was a problem communicating with google servers try again later" or stays on "checking info" for hours
This sounds like your wi-fi may need to be setup. If your phone was factory reset then you should have had to go through a Welcome setup which should have included wi-fi setup. If it didn't or you skipped or missed it, then do another reset and try again.
2answers
How to unlock s4 sgh-m919-ud?
Hi. What is the exact model of your Samsung phone? If you want to unlock your Samsung Galaxy S4, you can unlock it safer and easier using unlock code. You can get the accurate unlock code for your Samsung Galaxy S4 from ProUnlocking.com at affordable cost.
..............UNLOCKING INSTRUCTIONS..............
Method 1:
1 - Switch ON your Samsung Galaxy S4 with a NOT ACCEPTED SIM Card.
2 - Samsung Galaxy S4 will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Galaxy S4 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Galaxy S4.
3 - Compose : #0111*CODE#.
2answers
Hard reset samsung sgh
Samsung T499 Dart Android hard reset
1. Turn off Samsung Dart. Press and hold Volume up key + POWER on the
phone. Reset
2. When the Android System Recovery screen appears, release the keys.
3. Using the volume keys, scroll down to Wipe Data / Factory Reset.
4. Press the Power key to confirm.
5. With Volume select Yes -- delete all user. Press the Power key to
confirm.
After master reset select Reboot System Now. Press the Power key to confirm.
6. Your T-mobile Samsung Dart phone reseted to the factory default state.
(This should work but if not, try both volume + power)
Samsung T-mobile Dart reset
A Samsung T499 master reset restores the original factory settings and
may erase all downloaded content, including ringtones, images, programs,
and contacts stored in the internal memory. It does not erase data
stored on the SIM card or memory card (if available).
To perform a hard reset, follow these steps.
Samsung Dart T499 Factory Data Reset
From this menu you can reset your phone and sound settings to the
factory default settings.
1. Press Samsung Dart T499 reset - Samsung Dart T499 reset and then tap
Samsung Dart T499 reset settings key (Settings) - Privacy.
2. Tap Factory data reset. This action erases all data from your phone
except current system
software and bundled applications, or SD card files such as music or photos.
3. Tap Reset phone - Erase everything.
Samsung Dart Password code try 1234
or
Use this method to hard reset your Samsung Dart Android phone: Enter
*2767*3855#. Warning! All your data including contacts, messages etc.
will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM
or make backup to your PC before full reset! Take out SIM card before
full reset.
2helpful
How do i enter the nuc code on a samsung wave mobile phone
Samsung SGH-a300
*2767*637#
Samsung SGH-a400
*2767*637#
Samsung SGH-a800
*2767*637#
Samsung SGH-e400
*2767*688#
In newer phones:
#*7337#
Samsung SGH-e500
*2767*688#
In newer phones:
#*7337#
Samsung SGH-e700
*2767*688#
In newer phones:
#*7337#
Samsung SGH-E715
Turn off the phone. Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. Choose menu #7. After phone reboots type *0141# and hit the Call button. Turn off and insert another SIM Card. Turn on. The code is 00000000.
In newer phones:
#*7337#
Samsung SGH-m100
Type *#9998*627837793#. Then type *#9998*737#. Press >/[] (Play Stop) until phone shows NCK/SPCK number. Press Exit. Type #0111*CODE# (Code is the last 8 digits of the NCK/SPCK)
Samsung SGH-P400
*2767*3855# or *2767*688# or *2767*927#
In newer Samsung models:
#*7337#
Samsung SGH-s100
*2767*7822573738#
Samsung SGH-s105
Remove SIM Card. Enter *2767*7822573738# and after phone reboots, enter #0111*00000000#
Samsung SGH-s300
*2767*7822573738#
Samsung SGH-s307
In newer phones:
#*7337#
Samsung SGH-S500
In newer phones[/color]:
#*7337#
Samsung SGH-600
*2767*3855# or *2767*2878#
Samsung SGH-2100
Samsung SGH-V200
*2767*7822573738#
Samsung SGH-X100
In newer phones:
#*7337#
Samsung SGH-X600
In newer phones:
#*7337#
Samsung SGH-R210
*2767*3855#
*2767*2878#
Samsung SGH-D500
#*7337#
Samsung Universal Type
TEMPORARY UNLOCK:
Put a non-accepted SIM Card and turn it on. Type *#9998*3323#. Press Exit. You will get a new menu. Select Malloc Fail.
In newer phones:
#*7337#
4helpful
2answers
My G1 screen goes blank when i close it
First try SOFT RESET
1) Turn Off the Phone
2) Remove Battery
3) Remove Sim Card
4) Put battery and sim card again
5) Turn On the phone
6) Press Menu
7) Factory Data Reset (Remember that: This action will reset the phone to its initial factory state, erasing all data and wonloaded applications, so BACKUP BACKUP BACKUP first you try this).
Press "reset phone"
IF STILL NOT WORKING TRY:HARD RESET
1) Turn off the Phone
2) Press HOME + POWER KEYS (keep them holding for about 25 secs)
until you see a screen with a phone and a triangle.
then
3) SLIDE YOUR KEYBOARD TO OPEN IT
4) press ALT + l ( TO SHOW YOU OPTIONS)
5) Press ALT + W ( TO FORMAT ALL DATA)
Note: When I write the sign + you don't have to press the + sign, it means that you need to press both keys @ the same time.
May 03, 2010 • HTC G1
2helpful
I need the unlock code for my samsung sgh x 820 phone
You can unlock your mobile using instruction..Get the following instruction here mobileunlockguide.com
Method 1:
1 - Switch ON your Samsung X820 with a NOT ACCEPTED SIM Card.
2 - Samsung X820 will ask for "Password".
OR (if the Samsung X820 shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung X820.
Phone powers off automatically with the SIM card
hi, you can try to do factory reset,it don't make any harm to your mobile.if it doesn't work.we need to check with the sim holder,that may also cause of this problem.
3answers
Used Sidekick
Call your carrier and ask them to detach your device IMEI from the username locked in. Once that is done, hard reset without your SIM card inserted
Top Galaxy Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
Are you a Galaxy Cell Phone Expert? Answer questions, earn points and help others
