Question about Sony Xplod CD Player w/MP3 Playback CDX-GT50W
Sony cdxgt50w car cd player
Will not work at all! The 10amp fuse is not blown, and I am 100 percent sure that power is getting to the unit. Still it acts as if it is not hooked up whatsoever. I would like to fix it without buying a new one. Please suggest ideas
    Sergeant:
    Champion:
  • 231 Answers
If you are sure power is going to unit,There is a strong possiblity you have a burnt trace , main harness solder joints bad or shorted reverse polarity protect diode on main board .Also make sure you have power to both MAIN power (RED) and STANDBY POWER ( YELLOW) AND of course a good ground on radio chassis..
Posted on Nov 29, 2007
Im hooking a cd player into my 93 toyota pickup ive got the ground and the power hooked up but nothings happening what the deal
A fuse may be blown inside the unit. Before you install it, check its' operation with an external power source (12 Volts DC) to make sure it works first. If it doesn't power-up, check the fuse inside.
Nov 02, 2010 | Pioneer DEH-15 CD Player
The unit keeps blowing the fuse in the cars fuse box(10amp), the unit then does not work or display anything, but it still ejects the cd and takes it back in.
you have a short or the wrong amp fuse how can it eject or take it back in if the fuse is blown??? unless there is a secondary fuse somewhere is it wired into the accesory fuse it is possible it is wired into a spot that may have something else hooked in and your deck is overloading the fuse check to see that you have it so it is the only unit wired to a fuse
Dec 28, 2009 | Sony CDX-L350 CD Player
When i press the source button it will not change to cd and when i press the eject button the cd will not come out
On my CDX-GT20W, when it would not change to Aux input, I had to remove the faceplate and press the reset button to Reset the unit. The reset operation put everything back to factory defaults....which meant reprogramming all station presets, however, the entire unit functions as new. Hope this helps. Page 4 covers this.
http://www.docs.sony.com/release/CDXGT50W.pdf
Sep 29, 2009 | Sony Xplod CD Player w/MP3 Playback...
I have power going to the unit yet there is no display,a sony cdx-gt220,i know i have power because it is loading and ejecting cds yet no display.please help,its doing my nut in!!!!
I have a Sony CDX GT 530U. I had a problem with no display and I thought no power period. I did not try to install a CD, so maybe I did have power to the CD motor but no display. This was frustrating because I could get the old factory Nissan radio to power up and work so I thought I had a dead Sony unit. After a lot of monkeying around, I discovered I had blown a fuse while installing the unit (you should disconnect the negative terminal of the battery when installing the radio... which I thought I skip, that was a no no.). I had checked the auto fuses, those cheap little plastic fuses behind a panel below the stearing column inside most cars, at least all the fuses I thought went to the car stereo. Turns out I missed one that was labeled "Batt" or something like that, which was the constant power wire to the car stereo. There was another fuse for the Accessory power to the car stereo (the main juice went the key is tuned to ACC or Start position). Turns out the Sony unit display runs off the constant power, or at least the unit on/off button runs off the constant power wire, so even though the ACC power wire was live, the Constant power wire had a blown fuse and the unit would not turn on. Check all your fuses inside the car, I bet that's your problem. Constant power on my Nissan Sentra was a 7.5A fuse, while the ACC power ran off a 15A fuse, but your vehicle may vary. Good luck.
Jul 16, 2009 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
I had to disconnect the power wire to my KDCpmp435U, there is power going to the stero but the deck will not power up
are you 100 percent positive that there is power going to the stereo, i have installed for years and sometimes i suprise my self on little things i miss,
check the fuse at the back of the deck make sure the fuse didn't pop
and check the fuse in your car fuse box to make sure you didnt pop that one either, write me back if these still arent the issues
Jul 02, 2009 | Kenwood KDC-MP435U CD Player
Car will not start after installing CD player into a 1999 Saturn!
Check your Ignition 1 & ignition 3 fuses in the inside fuse block,also check the body fuse 10amp in the inside fuse block.Keyless entry should take back off once you found the blown fuse.hope this helps
May 26, 2009 | 1999 Saturn SL
No power to front panel but have power to main unit.
You Have constant power (yellow wire) but your Acc wire or switched power wire (RED WIRE) does not have power. Check the connection of this wire. You most likely have a blown fuse in your vehicles fuse panel.
May 19, 2009 | Sony Xplod CD Player w/MP3 Playback...
Got a new Kenwood KDC-128 car radio recently, fitted it but the radio presets would not stay when the ignition was turned off. Then it stopped working altogether and I noticed the 10amp fuse at the back...
you need to hook the yellow wire off the back of the radio up straight to the battery this keeps memory power to the head unit then wire the wires in color coded sequence red to red black to black so on and so forth if this doesnt fix it you might want to think about replacing head unit
Jan 02, 2009 | Kenwood KDC-128 CD Player
Pioneer deh 1600 has no power
Well.. if there is smoke coming from the head unit, the head unit could be bad. It odviously may have a wire crossed or a fuse blown, or even the wire harness could be bad. First, check the fuse for the radio on drivers side door, then check the other fuse box under the hood. Make sure all radio fuses are intact and not blown. Second, check behind the head unit to make sure no wires are touching each other and shorting out. Third, if nothing else helps, buy a new head unit & wiring harness :]
hope this helps!!!
Jun 12, 2008 | Pioneer DEH-1600 CD Player
Sony Marine Radio
check the wiring is installed correctly make sure you have a good earth & if it is a detachable face make sure the face is on correctly after trying this hold reset button for 15secs
May 16, 2008 | Jeep Radios: Genuine 6 Disc Cd Changer
Sony Xplod CD Player w/MP3 Playback CDX-GT50W Logo
133 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
