I want to install DirectX on my Dell Windows XP Professional desktop computer so I can play Disney's Dinosaur Activity Center on it. Will you please tell me how to do it?
Dell is available to help you on a wide array of topics. Whether your issue concerns technical Dial Our toll-free number +18002044427 get instant support for your query. Read More.. Dell Support Phone Number 1 800 204 4427
SOURCE: restore my dell dimension 5150
disable all integrated devices, change boot sequence to cd drive & then try to reinstall....
SOURCE: my dell pentium 2 with windows XP professional keeps restarting
There are two options of solving the problem according to my own diagonosis.
1. Remove the memory chip and replace it with a another one.
2. If it doesn't work then it should be a power supply problem and if its a l;aptop then its Battery failure.
SOURCE: FATAL ERROR MESSAGE/DELL OPTIPLEX GX150 DESKTOP/WINDOWS XP PRO
Optiplex 150 I get a message error loading operating system
can somebody help out there?
SOURCE: Acer Aspire 5735z Install XP
okay you might want to write this down make sure you have your product key #
put winxp
into cd drive then restart press F7 during restart then choose option start with cd or cd/dvd whichever you have
then press enter follow instructions YOU DO NOT want to press F6 for third party or raid let system go past that
then when asked to setup on the chosen space CLICK TO DELETE partition ( or unpartion ) then enter will ask to confirm
once all confirmed your installation will start
let me know how it goes MAKE SURE YOU READ ALL THE INSTRUCTIONS THE SYSTEM WILL GIVE
SOURCE: how to convert Pooh Days of Hunny Activity Center Exersaucer
Ok take the legs off of the top part (white) just twist and the top part comes off; then twist the springs off. Now take the legs that you took off and slide them through the first hole of the bottom from the bottom not the top; do all three legs and you have a table.
You can pop off the toys the tigger and flower one you have to push the thing till you have a big enough for it to slide through.
The disney pooh car pops right off of the top part; then you just unscrew the car from it's bottom (2 screws) take it off the track and volia you have a car.
I bought mine from someone but with a little bit of imagination I figured it on my own. lol.
software if you dont have the driver you will need to download one here rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
It might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
This will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you
want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
Hope this helps.
