Interthrm ac unit on but no fan blowing. is there an easy fix?
    Problem Solver:
  • 6 Answers
If your indoor fan is not running you have one of two problems either run capacitor is bad or motor has gone bad. Not sure if you can get a capacitor from home depot you can check make sure its at least a 440v and get exact MFD rating usually they are 5-7.5mfd
Posted on Jul 26, 2009
What is the problem? How do I fix it? Resistor Pack? Fan Control? Entire AC system?
your problem could be in your control switch panel itself. pull out the control panel and check the connections with a Probe Light Tester. The following video is for a Volvo but is used here only to give you an understanding of how to remove your A/C Control unit to check for poor circuitry. https://www.youtube.com/watch?v=SmCKFx1B4cA
Dec 17, 2015 | AC Cars & Trucks
Tip
Replacing a condenser fan in centralized A/C
On of the common problem with centralized A/C unit is a bad condenser fan. I have known people who called an ac technician to fix their ac because of a bad condenser fan and suggested replacing the whole unit! Costing them a lot of money when all it needed was a 50 dollars condenser fan! If the condenser fan do not run or it runs only when you give it a push, it'sbad. You will also notice that it is vey hot. When replacing a condenser fan you may want to replace the starting capacitor too. Replacing a condenser fan is not very hard, just make sure that the power to the ac unit is turned off at the breaker box. Confirm that the wires are not live by using a meter or an ac tester. The fan motor are held with brakets sometimes just screws. Most fan you can buy that has reversible rotation by just reversing the plug. Make sure it is blowing upwards. If not reverse the rotation. So if you notice that the unit is not putting out cold enough air and you went outside and noticed the compressor running but not the fan, turn off the AC right away and do not use it untill the fan is replaced. Running the unit with a defective fan can damage the compressor caused by overheating.
on Jul 10, 2010 | Heating & Cooling
My AC unit comes on, but the fan doesn't work or blow air
The condenser fan motor has gone bad... this is a very common problem. Find the specs. on the side of the motor and then get a replacement from Goodman or from a company like www.grainger.com
The fan motor is rather easy to replace, the worst part is getting the fan blades off of the shaft of the old motor. Use WD-40 and be patient...
heatman101
Apr 07, 2010 | Goodman CKL24AR24 Air Conditioner
Ac sytem blows strong air but its warm
If the compressor and fan work in the outside unit, and the fan inside (air handler) works, probably the system is low in refrigerant which means there's a leak that has to be fixed and then recharge the unit.
Sep 04, 2009 | Carrier 38CKC030 Air Conditioner
AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician.  The freezing up usually is associated with a low refrigerant charge or low air flow.  Check your return air filter and replace as needed.
May 30, 2009 | Heating & Cooling
Central ac blowing hot air outside fan not moving but making a noise
This is nothing but an either or -or ! First, make the thermostat calls for cool, there are suppose to be 2- noise outside, the fan motor and the compressor (and if a old system,a humming noise which is the contactor coil which picks up the main 240-volts).. hurry up and take a stick or something and turn the fan blades, if it picks up speed and run, then its the capicator. If not then the fan motor is bad.! (BOTTOM LINE)!
Jun 09, 2008 | Heating & Cooling
Maytag window ac unit
Feel the motor and see if hes hot ...... spin the fan by hand and see if it spins freely  if not the bearings have seized up.   So either rebuild the fan motor simply by replacing the bearings and oiling them and that should fix your problem.    IF the fan spins freely   OHM out the fan  and make sure there is no shorts or openings in the fan.     if your fan motor checks out good both mechanically and electrically  then your next step is to check the capacitor and control board
Oct 07, 2007 | Maytag M6D24E7A Air Conditioner
The fan in the outdoor unit does not work while the AC is on. The inside unit blows the cold air and the compressor in the outdoor unit is working the fan was not. How this issue can be resolved?
these motors are famous for the inyernal fuse blowing in the fan motor. check continuity between the red and blac wires. if there is non the fuse is gone. These motors are fairly easy to take apart and change the fuse . hope this helps
Apr 24, 2007 | Hitachi RAS-09UH Air Conditioner
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
