Question about Texas Instruments TI-84 Plus Calculator
Calculator won't graph
I did/changed something on my calculator and now when I try to graph it says I have invalid dimensions. I'm sure I'm messing it up trying to fix it. The window is set at -10,10,1,-10,10,1,1. So, I'm pretty sure that is right. Also, when I am trying to list things I messed that up too. How do I list ordered pairs. It only gives me the X coordinated, no Y. Thank you!!!
    Sniper:
  • 88 Answers
You have either entered data in lists where one list is longer than the other or in your y= screen, one of the plots is turned on. If a plot is turned on the letters are in white surrounded by a black box. To turn off the plots, higlight the plot that is on and press enter.
Another fast solution is to press, 2nd the the plus sign then the numbers 7 then 1 then 2. It will restore factory settings.
Posted on Aug 06, 2009
How to fix INVALID DIM in plotting graph
The ERR:INVALID DIM error message may occur
if you are trying to graph a function that does
not involve the stat plot features. The error can
be corrected by turning off the stat plots. To
turn the stat plots off, press y ,and
then select 4:PlotsOff.
• You specified a list dimension as something
other than an integer between 1 and 999.
• You specified a matrix dimension as something
other than an integer between 1 and 99.
• You attempted to invert a matrix that is not
square.
Apr 05, 2014 | Texas Instruments TI-84 Plus Calculator
Every time I try to graph on TI 84 it says ERR: INVALID DIM 1:QUIT I have enterered something simple y= x+2 and window is set for -10<x<10 and -10<y<10 the curser in y=...
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf to download the manual. On page 401, you will find the following:
INVALID DIM • The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff. • You specified a list dimension as something other than an integer between 1 and 999. • You specified a matrix dimension as something other than an integer between 1 and 99. • You attempted to invert a matrix that is not square.
Nov 11, 2010 | Texas Instruments TI-84 Plus Calculator
What does "ERR: INVALID DIM" mean and how do i fix it when trying to graph?
If you got the message while trying to draw a graph
  1. Press [2nd][Y=] (STAT PLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
If message popped up while doing something else that involves lists or matrices, the length of lists may be different, or the dimensions of matrices may not be compatible.
To Clear the lists:
  1. Press [2nd][0] (CATALOG)
  2. Press [PGRM] (C) to jump to first command that starts with c.
  3. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  4. Calculator displays Done
  5. Start the new problem.
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
When the RAM is cleared, the calculator is reset. The calculator resets itself after a battery change.
Aug 30, 2010 | Texas Instruments TI-84 Plus Calculator
Can't graph: Invalid DIM
Here .
To Clear the lists:
Aug 29, 2010 | Texas Instruments TI-84 Plus Calculator
When I try to graph I get an err: invalid dim Note: This started happening after I changed the AAA batteries
To Clear the lists:
Aug 14, 2010 | Texas Instruments TI-84 Plus Silver...
My TI-83 Plus calculator does everything it is supposed to do except that when I go to graph something it will not appear as a graph, but the table does show the points. Instead it says "EER: INVALID DIM"
Turn StatPlotsOff
Press [2nd][STATPLOT][4:PlotsOff][ENTER].
Calculator answers DONE.
You can Clear All Lists:
Press [2nd][0] to access the (CATALOG) of commands.
Scroll till you reach ClrAllLists
OR
press [PGRM] to jump to the first command in CATALOG that starts with C an then scroll to ClrAllLists
OR
Press [2nd][+] to open mempry Management and select [4:ClrAllLists]
Command echoes on main screen.
Press [ENTER]
Draw your graphs now.
Mar 16, 2010 | Texas Instruments TI-83 Plus Calculator
Having problem with ti 83 calculator everytime i graph it read error invalid dimensions
You must deactivate the statistical plots. If you do statistical graphs, the graphing is reconfigured in a way that happens to be incompatible with regular fuction graphs.
  1. To deactivate the statistical plots.
  2. Press [2nd][Y=] to access the (STAT PLOT) menu.
  3. Press [4:PlotsOff][ENTER].
  4. Calculator displays Done.
  5. You are ready to draw the function graphs.
Feb 15, 2010 | Texas Instruments TI-83 Plus Calculator
Graphing problem
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Mar 23, 2009 | Texas Instruments TI-84 Plus Calculator
I need help with graphing everytime i try to draw a graph it comes up with this ERR:INVALID DIM what does that mean
It means that your Xmin or Xmax is messed up. it often shows up when you are plotting somethings (histogram for exanple) and you don't have enough X or Y range to fit all the points in it. it also happens when you are multiplying matricies without using the right dimensions. ERR:INVALID DIM just means your dimension is invalid.
Mar 06, 2009 | Texas Instruments TI-84 Plus Silver...
Invalid Dimensions for Graphing and Equation
I suspect you are using the TINspire in TI84PLUS mode (with the TI84 keyboard).
If that is the case, the simplest procedure is to turn off STATPLOTS.
Press [2nd][STATPLOT] [4:PlotsOff][ENTER]. Calculator displays Done.
Hope it helps.
Nov 12, 2008 | Texas Instruments TI-Nspire Graphic...
Texas Instruments TI-84 Plus Calculator Logo
128 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
