Question about LG LSC26905TT Side by Side Refrigerator
Gasket melting because refrig is getting hot
My refrigerator is hot to the touch and is melting the gasket on the freezer door. What can be causing this
    Problem Solver:
  • 14 Answers
Where is the fridge sitting
Posted on Jul 26, 2009
LG side by side Model LSC 26905
Insulation does not melt - gaskets may be affected by hot temps.
Your condenser coils may be located on sides of fridge. If so the unit will be warm to the touch on the outside.
Jul 29, 2016 | LG LSC26905TT Side by Side Refrigerator
The front panel between the refrig and freezer doors is getting too hot to touch Would tht be a defrost timer or thermostat?
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Jun 09, 2011 | Refrigerators
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
Ice melts, then refreezes. Rubber Is HOT
Pull the refrig out , and remove the back panel . Is the fan that cools the compressor working ? Is the coil roll clean ? If the fan is not working , then the problem is probably the main control board . Behind the 8"X10" panel , above the compressor area . Remove the cover , and look for a burnt resistor , just to be safe . If this fan does not work , then the coils and the refrigerant line running between the doors , will get very hot .
Sep 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My freezer temp registers 28 - 36, I cleaned out coils, I notice that there is a fan in the back bottom right side, not sure what should make that run. My Ice is slowly melting. I had the freezer setting...
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Sep 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Area around freezer door is very hot to the touch. ice maker works, but after awhile the ice will melt. freezer is freezing.
HI, That area being hot is a sign the refigerator is not cooling properly. We need to pin point the cooling problem.
First, are you noticing any frost build up inside the rear freezer panel?
Are the fans and the compressor running?
Please let me know so I can assist you through this.
Vic
May 27, 2009 | Refrigerators
Refrig is hot to touch
Hi, Have you checked to see if there is a frost build up in the freezer? How are the temperatures in the fresh food side or the freezer side? Check and make sure the evaporator motor is running in the freezer. Please let me know if you find any of these issues. When that area is hot, usually there is more going on and the temps are not right. Let me know so I can assist you further.
Thanks
Vic
May 10, 2009 | Kenmore 53542 / 53544 Side by Side...
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
252 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
