Question about GE Microwave Ovens
Our microwave JVM1600 series stopped heating. everything else works. Should I just replace it? It is past warranty.
  • 3,037 Answers
Yes, just replace it. Most likely the magnetron is the culprit which heats the food and will cost 90% of the full price of a new one.
Benjamin
Posted on Jul 27, 2009
I have a GE Spacemaker Over-The-Range Microwave Model #JVM1533WD002 that has worked perfectly for 10 years. Now everything still works, except it doesn't heat the food. Where is the fuse located and how...
A common symptom of a failed magnetron is a failure to heat with everything else (magnetron fan, stirrer, timer, etc.) working fine. Check the GE manufacture date for the unit on its nameplate to determine the age of the magnetron. For GE models of the past, magnetrons had a 10 year parts replacement warranty. Magnetrons can be expensive, so you need to weigh all your options, i.e., repair versus replacement, before you commit to one solution.
Oct 04, 2013 | GE Spacemaker Over-the-Range Microwave
My recently purchased Rival RGST902 microwave stopped heating. Everything else works, it just will not heat.
HELLO.
The first wayout is to consider WARRANTY.If the microwave is under warranty return it to the point of purchase to enjoy warranty right.But if the microwave is not under warranty another wayout is needed.
Below is the solution on how to make our microwave heat food.
1 Remove oven racks and place them in soapy water to soak.
2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • Thanks.
    Sep 20, 2011 | Microwave Ovens
    Swan SM2050 microwave - everything works (light, turntable, LCD display) except it only sometimes heats and other times starts to heat but will then stop heating whilst everything else continues to...
    you not going to like me now!!!! in two words,,,,,dump it,,,, your microwave is well past its best,,to fix it will cost more than its worth, and to be honest there getting cheaper by the day now?
    Nov 28, 2010 | Microwave Ovens
    I have a GE Profile series microwave model #
    the magnatron has blown they are very expensive to repair i suggest you buy a new microwave
    ]hope this helps
    Jun 25, 2010 | General Electric Microwave Oven
    My Maytag microwave stopped heating. Everything
    Generally the magnetron (the part that heats the food) is the cause if everything else still works. Unfortunately replacing the magnetron is barely cheaper than buying a new microwave though you can check out repairclinic.com to decide whether you want to attempt replacing the part.
    Let me know how this works out for you.
    Benjamin
    May 24, 2010 | Maytag 2.0 Cu. Ft. Over-the-Range...
    Microwave stopped heating
    I had the same oven for one and a half years and had the same problem. Had the sears repairman come out and he said the magnetron burned out and needed replacing for $285. It was never under warranty with the warranty that came with oven. I couldn't believe it! We had an independent repairman look at it and he found a design flaw that causes the magnetron to blow. If you replace the matnetron (megnatron?) it will work for awhile, maybe, but then just need to be replaced again. It's cheaper to buy a new microwave. In fact, I got out our old microwave that's over 20 yrs. old and still works--just isn't as fast and as new ovens. Good luck!
    Jul 22, 2009 | Kenmore Microwave Ovens
    Frigidaire Professional series microwave won't heat
    The most likely problem is the magnetron. Check your warranty in owners manual, I believe you have five year warranty on magnetron.
    Mar 15, 2009 | Frigidaire FMV156DC Microwave Oven
    My GE JVM1600 Series went out.
    You can download GE owner's manuals and installation instructions here.
    It will help you, I'm sure.
    Dec 10, 2008 | GE JVM2050 Microwave Oven
    Not Heating
    It appears that all of your microwaves have bad magnetrons.
    If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
    But they send you a replacement magnetron. GE Customer Service is here.
    Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
    http://www.gallawa.com/microtech/diode.html
    http://www.gallawa.com/microtech/mag_test.html
    http://www.gallawa.com/microtech/xformer.html
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
    There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
    Sep 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave won't heat food.
    built in 3/94 is it worth fixing how much for magetron
    Dec 30, 2007 | Maytag MMV1153A Microwave Oven
    Microwave Ovens Logo
    247 people viewed this question
    Top GE Microwave Ovens Experts
    D. E. Hev
     Larry
    Larry
    Shekar Avadhani
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
