Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer works but fridge stays at 57 degrees
I keep seeing things on here about a glass tube, how do I locate it on my fridge!
  • dondaa3 Jul 26, 2009
    Ice build up is at the back of the fridge. where is the heater and thermostate located after removing the styrofoam?
    President:
  • 744 Answers
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! and thanks for using Fixya. Mike
Posted on Jul 26, 2009
  • Mike Price
    Mike Price Jul 26, 2009
    Ok if this is a side by side and you have ice in the fridge thats a complete different kettle of fish, your problem is going to be with the cold control not the defrost system, Basically what is happening is the cooling system is not shutting off. The fridge is nothind but a box with a vent connecting it to the freezer. If the thermostat/cold control does not work it won't shut down and your food begins to freeze also ice starts to build up in the fridge...You should locate the knobs in the fridge that control the temp and remove the panel. then you should replace the thermostat which controls the temp of the freezer...the fridge knob is just connected to the vent. once you have replaced the cold control you should let the appliance defrost manually for 24 hours to get rid of ice build up. Mike
Refrigerator
The self defrost mechanism is not working. The evaporator is getting blocked with ice, an insulator, and that affects freezer as well as refrig temps. When you unplug unit the ice melts and it will work till the ice block returns.
Sep 07, 2016 | Refrigerators
Samsung rf217acpn/xaa fridge not staying cold and ice build up.
Be sure the drain is clear these are well known for drain blockage. the area behind the shelves is where you would find the evaporator and drain hole.
"Always disconnect power before trying to repair any appliance."
Jul 11, 2017 | Samsung 19.7 Cu. Ft. French Door...
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
The freezer works but the refrigerator section is 55 degrees. I turned it off overnight and a quart of water came out the bottom. I plugged it back in and it worked great for 2 days (refrigerator at 38...
I suspect your real problem is not the defrost drain being plugged but a defrost issue. It sounds like your fridge is not defrosting causing a lack of air flow to the fridge section. You can remove the inside back wall of the freezer to expose the evaporator coils and see if they are all frosted over. Your defrost drain is below the coils in the center of the opening.
Most likely the defrost thermostat has failed. This part is also located in the freezer and is clipped to the coils on the top right hand side. It looks like a small round thing and usually has a pink and orange wire or a pink and brown wire attached to it.
The other possible culprit could be the defrost timer that is located int the ceiling of the fridge section next to your controls.
Jun 13, 2010 | Amana DRB1901C Bottom Freezer Refrigerator
Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Jan 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Side by side freezer works fine ice cold.fridge not so good. only at 57 degrees
Listen for the fan motor to run. Open the freezer\ push the door switch with your finger \ listen for the fan that blows the cold air to the fridge. only the freezer side gets cold...fan blows cold to the fridge side. If the defrost timer has broken then ice may be blocking the flow of cold air to the fridge also. Only 2 things to check. Good Luck
Dec 11, 2008 | Kenmore 57029 Side by Side Refrigerator
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Samsung 2556 refer
I had the same problem, I removed the shelves and the lower panel behind the shelves...Behind it their was a radiator like contraption, it was ENGULFED WITH ICE......I used a hair dryer to melt the Ice , and the problem went away....Thats all I can offer you...
May 06, 2008 | Samsung RS2578BB Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
233 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
