Question about HP DeskJet 940c InkJet Printer
HP deskjet 940 c
My printer stopped working as soon as I inserted a new cartridge. I did make sure that it was the right one for the machine - hp 15 black.Now what happens is that the first of the three lights is blinking amber and the third light is a steady green. When I give a printer command nothing happens except that the printer section of the control panel tells me that the document is being printed.
  • 1,601 Answers
Re: HP deskjet 940 c
0 characters
3 Points
How do I insert Ink Cartridge into HP Deskjet 1510. Do I need to have 2 cartridges inserted. Only use other details
You can follow the link. Yes you do have to install 2 carts. to work the printer. However from printer setting you may disable color print.
Note Ink cart head gets clogged when not used prolonged time.
Thanks. Replacing Cartridge HP Deskjet 1510 All in One Printer
Mar 05, 2015 | HP Deskjet 1510 Allinone Inkjet Printer...
My HP DeskJet 920c prints pink instead of blue, new cartridge has been cleaned and blue is visible on swab.
Try running multiple "head cleanings" on it, or you might have the cartridge in the wrong location (if thats possible on that model). If not, then the interface board on the printhead may be faulty or the ribbon cable the sends the signal to the printhead assembly. Most of the InkJet printers made now days are considered disposable electronics by the manufactures. Due to the low price point and the lack of parts support or cost of labor to repair when they do stop working right. Good Luck
Jun 07, 2012 | HP DeskJet 920c InkJet Printer
I have an hp officejet pro L7680 printer and am having trouble finding new 88xl cartridges for it. Will the 940xl cartridges work in this printer
You cannot install HP 940 Cartriges for Officejet Pro L7650 as they are not compatible and the mechanism is different for both the cartridges,
In your printer, the HP 88 fits on the left bottom corner of the printer and the HP 940 cartridges are mounted on the Printhead inside the printer on HP Officejet 6500 AIO.
Apr 19, 2012 | HP Officejet Pro L7680 All-In-One Printer
I can not locate the HP 940 cartridge o the printer in order to replace it. Can you tell me where to look for the print cartridge?
Hi, no problem. Switch Off
As you look at the front of your printer to the left of the paper tray you will find the black facia is a drop down lid drops towards you revealing four cartridges.
Withdraw the cartridge in question note which way up and pull out at the same angle it is inserted.
Renewing, place the right way up and remembering angle gently insert new cartridge with a firm hand and you will feel a slight click as it locates.
After thought, please remember when ordering replacement to mention/make sure it is the wireless replacement, the 8500 (Non Wireless Printer) cartridge is not compatible.
Mar 22, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I just hooked up my hp printer to my Gateway computer. It will not print In the print box it says there is an error. I've used these two machines together before and never had a problem. Please help.
Please reboot your computer and the 940 too. Check the cable and connectors, are they tight? Make sure the screws are tight on the cable connectors and inspect the pins as it sounds like you use this printer on several computers?
You should reinstall the print drivers and if you have lost the CD you will find the software at the HP site on the left side of the page:
If the cable is good and the software leaves you with the same problem then I must tell you that this printer is too old to repair. This printer was produced in 2000 and I am not sure about when they stopped making them. It was a great printer but it may be past its prime. You may have a failure in the 940. A new single function HP Printer can be purchased for half the price of trying to find someone to fix this printer. The new HP Printers are much more thrifty when it comes to ink than the 940 and they give much better color results too.
I hope this helps
Oct 16, 2010 | HP DeskJet 940c InkJet Printer
I have an hp deskjet 5550 printer which used to be connected to my previous computer. My current pc has Windows Vista and although the printer works it just prints in tiny faint text and won't use my new...
Sounds like the working cartridges are badly clogged. Is the new cartridge HP brand or an "internet special"? Try HP originals and see if the machine still works ( I imagine it will). If not, then yes the machine is probably and the end of its life.
Jun 08, 2010 | HP DeskJet 5550 InkJet Printer
Printer (HP deskjet F4180) showing E and color
This means that there is issue with the Ink Cartridges.
Please remove and re-insert the cartridges.
Check the expiration date on them. Also make sure that you are using genuine HP Cartridges, not refilled or Remanufactured.
If the issue still persists, please replace the ink cartridges.
Jun 02, 2010 | HP Photosmart 2575 All-In-One Printer,...
Problem with hp deskjet 640c printer
i have an hp and find that they (color carts) cannot be refilled- the clever b*st*rds!! they stepped the ink reservoirs so, if you don't insert the re-fill needle 'just right', it bleeds into the others and you end up with a 'muddy' print-out! you need to buy a new hp cart, or shop around for a generic cart (cheaper) google your product & cart #. you may find a source for a cheaper cart.
the black carts. can be re-filled!
good luck!
Oct 08, 2009 | HP DeskJet 882c InkJet Printer
Paper Jam Issue with the HP Deskjet 5440
Clean the contacts on the HP Cartridge. I've had the same error before and i switched it to a fresh new cartridge.. works fine ever since. THen i decided to switch back to the old cartridge, same error as you but i cleaned the contacts on the cartridge, works for a while but done after a week. Problem is that the ribbon circuit is rusted and the printer doesnt recognize the ink anymore.
Also make sure you both have the ink cartridges in place. Make sure it is seated properly inside.
hope this helps!
Mar 20, 2009 | HP Deskjet 5440 InkJet Photo Printer
HP DeskJet 940c InkJet Printer Logo
123 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
