Did you check your fuel filter? Did you have a shop install the sensors? If they are not positioned in correctly, it won't work. Have you had your fuel pump checked as well? That's in your fuel tank. With this high end car, there may be a reset code as well.
sounds like you may have clogged the fuel filter due to debris on bottem of tank or burned out your fuel pump , Id try spraying starting fluid in the air filter duct and see if it starts then , if so you found your problem via above!!!!
verify that you have a fully charge battery and that you have the same amount of voltage at the battery as at the starter when the key is turned to the start position. If not repair fault at positive cable either at battery or at starter. If voltage checks good. Use a remote starter and turn key to the on position and try to crank over engine with remote starter. if engine cranks over. You have a defective starter solenoid and starter must be replaced.
you have to turn the switch on and off, but dont crank, you will hear the fuel pump come on then go off, keep doing this for a few minutes and it should start
