Back to:
Tags:
Kitchen Ranges
Generic problem for all Kitchen Ranges
Amana oven gas leak issue
posted by Cantfixjack on Nov 22, 2007
Our 12year old Amana gas oven has a gas leak smell when we turn the oven on. The ignitor starts up and lights the gas, the oven heats up, but still smells of gas. We turn it off of course. I wonder if it is the ignitor. Also, two of the top burners will no longer ignite, they can be lite by a match. I would say time for another range but it's in great shape otherwise. Can these problems be fixed?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 22, 2007
Thanks for Trying (70)
staunch
Rank:Apprentice Apprentice
Rating: 70%, 1 votes
if you only get a gas smell when you turn on the oven then it is not likely you have a gas leak- the ignitor resistance drops as it heats up and when it drops low enough the main gas valve opens and the gas ignites from the hot ignitor. If however you have a gas smell all the time and have to shut off the main gas valve (at the flex line) then you have a problem. Not sure where you are located but here in the bay area (CA) our local utility company will come out and do a leak check  for you gratis. As for the burners not lighting- do you see a spark at the burner you are trying to light? If so, the burner is dirty. If you don't here a clicking sound when you turn the know the igniter switch is probably bad.
Rating Locked! (?) Cantfixjack has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Amana oven gas leak issue:
I don't want to Accept this solution
Can you Help with these Kitchen Ranges problems?
GE Profile Spectra JBP95 Electric Kitchen...
The probe button is non responsive while trying to use the...
Kitchen Ranges
Maytag gemini MGR6875ADB after a 8 hour power outage the...
Kitchen Ranges
I need a new propane supply hose for a masterbuilt turkey...
Frigidaire FGF378AC Gas Kitchen Range
The burners are trying to ignite at random times. The...
Estate TEP325K Electric Kitchen Range
Purchased home with oven already present - without the...
Loading problems.
Repair Service
Find Kitchen Range Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
