Question about Danby DAR259BL 2.6CF Silhouette Compact Refrigerator
Danby freezes all beverages
Are small beverage refrigerator freezes everything solid even on lowest setting
  • 27 Answers
Check position of thermistat bulb it should be on the plate
Posted on Jul 29, 2009
  • mike Sanchez Oct 03, 2011
    Where is this bulb locate?
    New Friend:
This happened to ours. Appliance service company told us that the thermostats are junk and too costly to replace. Ended up buying a new unit.
Posted on Dec 26, 2015
Even on lowest setting, drinks too cold, freezing at back, ice.
Thermostat needs replacing. Can`t find one online but I would guess a standard Danfoss would do it.
Mar 18, 2016 | Whynter Beverage Refrigerator
Beverage Air MM14 wont shut off, freezes everything !!
Have you turned the thermostat to it's lowest setting? If so then the thermostat needs to be replaced.
Jan 11, 2015 | Refrigerators
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Cooler keeps freezing product
You killed the messenger! The refrigerant charge is probably the problem. The thermostat senses the coil temperature and not the cabinet temperature. If somebody put gas in it, the gas has to be removed, a vacuum drawn on the system and then the refrigerant charge weighed in by the ounce. It takes a critical charge and needs to be weighed in by an accurate scale that weighs in ounces. Hope this helps and good luck.
Jul 17, 2014 | Beverage-Air MT27 Beverage Cooler...
Danby DBD5L Beverage Dispenser
If your problem was chainsaw related I could help you. I think you would get answers under another heading.
Dec 05, 2013 | Danby DBD5L Beverage Dispenser
Fridge that freezes
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 29, 2011 | Danby DBC514BLS 5.3 Cu. Ft. Beverage...
Danby DAR259BL 2.6CF Silhouette Compact Refrigerator Logo
442 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
