Kohler 20 HP Courage S600
Take the nut and cover off of the fly wheel. you should see the fly wheel key if it is sheared then it need to be replaced. if it is still aligned correctly it is good. you need fuel spark and compression to run. spray some carb cleaner in the carb. if it starts for a second something is wrong in the fuel area. you should see spark on the plug and block. check compression to be sure you have at least 40 lbs. if not the valves are probably not set correctly. assuming you got the head gasket on right.
