Question about HP Color LaserJet 2600n Printer
Unclear image when the paper comes out of the printer the printer starts to make noises like scratching and the printed page comes out it has a something that looks like black roller marks all over the page
  • 40 Answers
If the ink-marks repeat on papers,need to clean roller paper by doft cloth.
Posted on Jul 27, 2009
2420 printer printing very squiggly as if you are looking at a reflection in water that has currents in the water, this is not a toner issue
Looks like you have a clogged/possibly damaged heads and head alignment issues. Do the alignment procedure and check the manufacturer support website or Google for the factory reset button combination of the printer. Cheers, Mike.
Apr 07, 2016 | HP LaserJet 2420 Printer
Black line coming while printing on hp m5025mfp
the problem is in fuser or in toner cartidge.
print a page when the printer start to pull the paper more than a half page stop the printing by open the door
remove the toner and look the paper
if you see the line the problem is from toner replace toner cartidge if you see the image ok means the problem begins when the paper go into the fuser so replace fuser.
Feb 20, 2014 | HP LaserJet M5025 MFP Printer
Printing too light
For understand the issue, little bit technical knowledge required: Take half test page, check how much dark image formed on paper, check on cartridge drum how much dark image created?..(half test page: while printing half of the page switch off the printer, take cartridge out as well as take half printed page)If half page print quality is good on paper: Fuser faulty(teflon sleeve)If half test page print not good & image on drum is OK: Fault with Transfer roller or its bios voltage contacts..If there is proper image on paper & image drum: Problem with laser scanner assembly..find the problem, then remedy is easy..
Feb 02, 2012 | HP LaserJet 3030 All-In-One Printer
My laserjet printer started making load noises and no longer prints-the last thing printed only printed the top 3inches and then was all black, it then stopped working altogether
Use the following checklist to ensure that the print cartridge is still operable:
  • Ensure that the print cartridge is seated properly.
  • Inspect the print cartridge for remaining toner.
  • Check the expiration date stamped on the print cartridge box.
  • Check the print cartridge to see if it has been disassembled or refilled.
  • Inspect the print cartridge to see if toner is leaking through worn seals.
  • Check the surface of the photosensitive drum in the print cartridge to see if it has been damaged or scratched. Touching the drum contaminates the photosensitive surface and can cause spotting and image defects.
  • Blurred areas on printed pages indicate that the photosensitive drum in the print cartridge has been overexposed to light. Because overexposure to light causes permanent damage to the photosensitive drum, the cartridge should be replaced.
The HP LaserJet 1100 series printer cannot print to the edge of the paper, to get the image to fit into this printable area, slightly reduce the size of the image.
try this and let me know, also check the status of the toner.
mail me- raaj_k001@rediffmail.com
Jan 12, 2011 | HP LaserJet 1200 Printer
When i print ,I get this error 'Manual Feeder Paper Empty
You are most likely getting this message because of a paper size mis-match. For example, you are sending a print job as letter size but your printer is set to or has a4 size installed. When the printer sees that the print job is not a matched size to the paper in the tray, it will look to the manual feed tray for paper to print on, hopefully the correct size. Make sure your paper setting in printer properties on your computer match the paper in the printer and the print job "page setup" is also the same size/
Oct 06, 2010 | Samsung SCX4623F Laser All-in-One Printer
The images are too big.
go to the printer perference or setting on your pc, there is option says scale to fit the page, click it , and some of printer allow you to select the paper size you are using. its simple problem its just driver setting issue.
Good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 19, 2009 | Dell Office Equipment & Supplies
Hp2820 noise when printing
Try substituting a new imaging drum. The problem may be a bad bearing.
Oct 09, 2008 | HP LaserJet 2820 Printer
Printer leaves black spots on paper
The black spots mean you either need a new imaging drum, transfer kit or fuser. You'll have to print some stuff and try to catch where the black marks are appearing. Try this method (it's called a Half-self test)
Load 2 -3 sheets of letter paper in tray one (manual feed) and remove paper from the rest of the trays.
From the information menu, request a demo page
The MOMENT the tail end of the paper disappears into the printer, open the right door. Open the front doors and release the levers for the imaging drum and the transfer drum. Carefully remove both pieces and examine your paper.
You should find the paper partway on the transfer belt but not in the fuser. If you see black marks here, start with the imaging drum. Open the shutter that covers the sea green shiny roller and look for marks on the drum (you'll see build up on the edges, that's normal, you should not see any scratches, pockmarks or toner on the center of the drum). If it looks clear, take a look at the transfer drum for marks or cuts on it's surface. (note: the transfer drum can be cleaned off with a dry lint free cloth, do not touch the shiny sea green roller of the image drum)
If everything looks good there, then likely the black marks are coming from the fuser. Let the printer sit, turned off for about half an hour to allow the fuser to cool. You can then remove the fuser and look at the rollers to see if there is any build up or damage there.
If you are not seeing any obvious issues with any of these parts, then start with the imaging drum. If you know that any of these parts have never been changed, then change them as they do have a limit to how many pages and how much time they can be used for.
Sep 16, 2008 | HP DeskJet 6540 InkJet Printer
Scanner & black pages
The black printing usualy occurs when there is a faillure in the light, since your light is working fine, there may be a problem in the imaging device inside(camera) or the reflector. There is nothing wrong with the cartridge.
May 05, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP Color LaserJet 2600n Printer Logo
104 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
