Depending if its plastic you can remove the dent using a heat gun and a tap around the bump usually pop out. removing the bumper there are screws on the sides behind the wheel arch covers and 4 bolts around 1 foot away from the corners, if your model has sensors in the bumper they will need to be discounted. also any other wires that are they before you pull off the bumper.
SOURCE: dented rear bumper, how does bumper detach to pound out?
is it a rubber bumper? use suction cups, thats what dent specialist use instead of takin off the entire bumper. use a winshield dashboard suction cup for example. Just be creative...
SOURCE: 2004 toyota rav4 rear bumper assembly guide
there are two bolts to the center and two around the corner on at the edge up high and one at the bottom of the bumper/ Please rate my response thank you very much
SOURCE: how do I remove the back bumper (plastic) on a 2003 toyota camry?
you can heat the bumper heat gun ( you can rent one i think?)
this will soft the bumper so you push it out easily on the car
1. inside your trunk remove small back clips in trim panel
2. remove tail lamp four 8mm nut perside unplug wires
3. remove black clips under tail lamps ( flat head screwdriver to pull center of the clip up slowly then remove the hole clip)
4. three if the some clips are bottom if the bumper
5. three or four 10mm nuts in side the quarter panel on the right and left side
6.four s shape clips are top bumper that will pull loose
7. with some help slide bumper by pulling it off it
8. when you reinstall the bumper you may need to tape the strophe reinforcement in place
SOURCE: My Toyota Corolla rear bumper has at big dent on
you have to take the whole bumper off and the bolt the u see holding it on the re-bar and bumper cover should come off
