Question about Kenmore 24032\24036 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
Describe your Kenmore 24032 24036 Top Load Washer Problem When the machine goes to discharge the rinse water while spinning water leaks out of somewhere onto the floor. How do I diassemble the unit to further troubleshoot?
    Scholar:
  • 84 Answers
MAke sure that the cothes are not unbalancing the tub. Iv seen this happen where the clothes are unbalancing the tub and it moving around and the when the water for the rinse is coming out its not getting in the tub its splashing on the top of the tub ring due the the unbalanced spin. does this happen when you wash a heavy load? do you notice it not doing that when you washer a light load?
Posted on Jul 26, 2009
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Oasis HE 27082 Front Load Washer
ohm the release solenoid. could be shorted or open. check for voltage to the circuit
Sep 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
That is a bad water valve. Try my washer PICTORIAL for directions on replacing that water valve. NOTE: this is a pictorial of how to replace your drive coupling but you need to bust this ****** loose to get to that valve.
Jul 06, 2009 | Kenmore 24032\24036 Top Load Washer
Hi, Make sure the washer is solid to the floor. To level the washer, Put your foot against the front panel at the floor and tip the back of the washer toward you. Then set the washer back down and the rear legs should self adjust.
Hopefully this will stop the washer from shaking.
Vic
Jun 30, 2009 | Kenmore 24032\24036 Top Load Washer
Water pump is my first guess. Did you check the hoses that hook to it? The pump is in the front of unit. Give full model number to further assist you.
Jun 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 22622100 Top Load Washer won't drain the water, nor rinse
HI!!! you seem to have a bad lid switch on your washer..I would also check the timer on it good lucck.
Feb 13, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer overflows during rinse cycle.
SOME OF THESE MACHINES HAVE TWO PRESSURE SWITCHES IN THEM, ONE FOR THE MAIN WASH WATER LEVEL AND ONE FOR THE RINSE WATER LEVEL. CHECK FOR A PLUGGED AIR PRESSURE HOSE FIRST AND THEN CHECK THE PRESSURE SWITCHES.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
No cold rinse
check to see that the hot and cold pipes are not crossed over
ie the hot pipe is on the cold tap
when machine goes into rinse cycle it only uses cold water
Nov 09, 2007 | Kenmore 15864/15862 Top Load Washer
No rinse
Make sure that you have both, hot and cold water connected and turned on. Some models will not advance through rinse if one of the hot or cold is off. See if this solves the problem, Catriver.
Jul 21, 2006 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore 24032\24036 Top Load Washer Logo
207 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
