Question about Toshiba 52HM95 52" HDTV Projection Television
Make loud buzzing noise when powers on
When on noise stay until powers is turn off
  • 261 Answers
Actually that buzzing sound seems that it might be an issue with your ballats, it may start to go out sometime soon.
Posted on Jul 27, 2009
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Samsung s3 phone wont turn on only red light stays on and a buzzing noise sounds and wont turn on need help
Shut it down by holding the power button until the screen goes black, don't tap the power off button, wait for the black screen. Then let your phone charge for a few hours (maybe over night) with power off and see if that helps.
Dec 12, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Why does my car make a loud humming noise?
The buzzing noise is air in the power steering line. The reason it is only one n one side is cause when you turn the wheel it causes more pressure to build. Take the cap off the reservoir and turn the wheel back and forth all the way hold for a second on each side until the buzzing noise goes away. If that don't work then check your rack and pinion system to make sure you don't have leakage or damage from road debris.
Sep 07, 2014 | 1995 Mazda Protege
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
Dec 13, 2013 | Precor C956i Treadmills with HR /...
My 2006 chevy cobalt is making a loud buzz when in park and ac is on
Anytime the a/c is turned on the cooling fan will come on so that the engine does'nt over heat.It will not turn off until the ebgine has colled down.
Nov 02, 2012 | 2006 Chevrolet Cobalt
Loud pop and then buzzing noice mitchubishi 1080 p
Unplug the set and do not plug back into power until see is opened and examined. It says Mitsubishi here but what is the model number as it is not indicated here.
Jun 03, 2012 | Mitsubishi Televison & Video
Loud buzzing on Wahl "Designer" model clippers
There is a "power screw" located on the side of the clipper opposite the switch. This may need adjusting. Take a screw driver or coin....and with the unit running......turn the screw back and forth until the clipper stops making noise. The proper position for the most power is to turn the screw intil it makes a loud noise, then turn it back just enough to get rid of it.
Jul 03, 2009 | Wahl Designer 6 (8355100)
Loud buzzing noise
Yes,it sounds like the color wheel motor is going,and yes it satais on untill lamp cools down
Oct 13, 2007 | Toshiba 62HM95 62" HDTV
Toshiba 52HM95 52" HDTV Projection Television Logo
208 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
