Question about Bosch Dishwashers
4 year old dishwasher no longer draining water
Approx 4 year old dishwasher no longer draining water dirty. hose pipe not blocked have removed small chicken bone from impellor.
still not drsining.
bosch classix sgs4012GB/13
  • 98 Answers
Check out my guide HERE. It addresses other problems you can have with bosch drainage. Tell me what you think!
Posted on Jul 26, 2009
My Frigidare dishwasher is not draining so I cleaned the filter. Will there always be a little water left in the lowest part where it drains?
There will always be a small amount of water in the bottom because the pump is an impellor type, not syphon or peristaltic. The water will be whatever is in the drain pipework after the drain cycle has finished. If the machine is leaving a lot of water, the it would be worth checking the drain hose isnt blocked or kinked, and the drain pump impellor moves freely
Jan 11, 2018 | Dishwashers
My samsung dishwasher will not drain? What could be causing this problem. We checked the line and it is not plugged.
when you first start the dishwasher the first thing it will always do is drain, does it make the normal draining sounds or is it a low pitch humming noise? if its a low pitch humming something is stuck in the drain pump like a peice of chicken bone or glass, if it sounds normal then there is a blockage somewhere and 9/10 times its the little drain spiggot that the drain hose plugs onto under your sink, they often block up as the pipe diameter gets smaller there
Oct 08, 2014 | Samsung DMT400RHS Builtin Dishwasher
Fisher and paykel dishwasher top draw does not unload water after the wash
The pump is faulty or the drain hose is blocked. You need to take the pump rotor out from the base of the drawer and inspect the sump for blockages. Usually a seed or chicken bone stuck between the drain sump and the pump rotor sump.
Nov 26, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
Water Won't drain fro the dishwasher model Blanco bfdw650s
If you "Lower" the hose to the bucket and it "drains" you are just using gravity to remove the water. The pump may be helping a little but if you raise the hose up and the water stops coming out, it's a good indication that the pump is bad. Unless the place you are attaching the hose to is plugged up, you need a new pump or a new impellor. Since the motor is good, try to get a replacement impellor, that the thing that moves the water. One other thing, you did say how well it washes the dishes? If the impellor is bad, it probably doesn't.
Sep 08, 2009 | Frigidaire 24 in. FDB126RB Built-in...
The last one to two inches of water does not drain out
It sounds like you have something in the small water pump at the base of the dishwasher that pumps the dirty water through the hose into your sink drain. Remove the lower front panel of the dishwasher, unscrew the hose clamp and pull off the hose, then unscrew the pump so u can inspect it. Usually you will find a chunk of glass, or bone or other debris which is blocking the pump partially.
Apr 15, 2009 | Dishwashers
Water not draining
your chicken wish bone may have broken your drain pump- it may have prevented the impeller to spin while the motor was on-not good. you may want to consider changing the drain pump...
Mar 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Not draining water beko dishwasher
--probably food particles blocking impellor on pump--clear pump or drain hose is kinked or blocked where it enters pipe under sink .Always scrape plates clear of food particles before placing in dishwasher
Jun 25, 2008 | Dishwashers
Maytag model 920 d/w will not drain
can you hear the drain pump trying to pump? or does it do nothing? when it should be draining
Feb 19, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwasher not draining
The drain pump maybe jammed - this happened to me; a small piece of chicken bone got past the filter.
I took the bottom panel off to access the pump, removed the debris, put it all together and it's worked fine since (over a year). It's a messy job, with all the water etc, but it's taught me to clean the filter regularly :-)
UNPLUG FROM THE MAINS AND WATER SUPPLIES BEFORE ATTEMPTING THIS. ELECTRICITY AND WATER DON'T MIX AND CAN KILL.
If in doubt put your hand deep in your pocket and call out a tech.
Dec 07, 2007 | Indesit 24 in. IDL500 Built-In Dishwasher
Dishwashers Logo
438 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
