Question about Hunter Fan Co. 60 In.Brushed Nickel Stonebridge Remote Control Ceiling Fan
Hunter ceiling fan. Lights and fans turn on and off by themselves.Both fans are on the same wall switch and are operated by separate remotes.
  • Deets55 Jul 27, 2009
    jmaesoliver, Thanks for your response, but they are already on different frequencies. With wall switch on, one light only on, either fan may come on at any speed, or the other light may come on. If left alone the fan may change speed, or go off, also the light may come on and off. No pattern, or false signal from TV Remote or other interference.
I just installed a 2nd hunter fan model 23811 that also seems to be controlled by grimlins. If the power is left on, the light and fan randomly turn on and off. And no, it is not due to fans being on the same frequency. It appears to be an issue with the control module. I'm contacting Hunter.
Posted on Mar 16, 2012
  • 1 more comment
  • chuckles
    chuckles Jun 06, 2014
    The problem you describe could be a "frequency" issue since all electronic parts have a "tolerance" that aging and temperature can cause to vary. And, it is possible an incorrect part that was "close to value"
  • chuckles
    Add a Comment
  • chuckles
    CONTINUED . . . installed making the tuned frequencies interfere with one another much like "AM radios" tend to often do. Incorrect tuning values will cause insufficient frequency band separation and cause interference. Hey, a faulty component such as a "capacitive" component could dynamic vary the frequency separation???
I know this is an old thread, but I just fixed this problem on my Hinter ceiling fan. If the lights are flickering on and off, it sounds like the wattage controller (inside the ceiling hub) is the problem. I've heard Hunter sells them for $35, and I've seen YouTube videos showing the easy procedure of cutting these out. I cut mine out, and the lights work properly again.
Posted on Jun 24, 2015
    Sergeant:
    Scholar:
  • Hunter Expert
  • 96 Answers
Obviously you have 2 (two) hunter fans with remote, so one of the fan needs to have frequency changed : on the base fan you will find (white rectangular )receiver that has 8 (eight small) switches, the same switches you would find in the remote control, slide 1 switch up ( on the remote and the receiver). Make sure same number ok (these 8 switches has #'s 1,2,3,4,5,6,7,8) then reinstal your fan back the way it was. you'll be fine. good luck
Posted on Jul 27, 2009
  • Robert Griffith Mar 17, 2015
    My receiver don't have dip switches, Im pulling my hair out! Brought 2 hunter fans and my fan remote operates my kids fan. Some times my light turns off! I performed the steps of resetting remote and it still doesn't work. And yes it's brand new stuff and yes I'm mechanically inclined. Not to impressed with Hunter remote devices!! Help:(
Install a hunter highland remote in a prewired house that has 2 lights on the same main switch
Prewired for ceiling fan (colors, installing, bedroom, lights ...
www.city-data.com > City-Data Forum > General Forums > House
Jan 29, 2009 - 10 posts - ‎3 authors
In my new house, there's 2 switches so I can do them separately. ... is there anything else I can do with that switch since the fan has a remote and I won't be using it much? TIA. .... Those same wires should be in that switch box.
Wiring on ceiling/fan light combo with remote and ... - Bob Vila
www.bobvila.com/.../82070-wiring-on-ceiling-fan-light-combo-with-re...
Oct 3, 2007 - I can have installed the fan/light (a Hampton Bay Veranda) without the ...My house wiring has a green ground and two black and two white wires. ... Fortunately I found a universal/all brand fan speed control wall switch made by Hunter. ... i havethe same problem . so you just did not used your remote?
Jan 19, 2016 | Hunter Dryers
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Have a hunter ceiling fan with light kit and remote. Lights have started turning on and off by themselves ?
This is likely caused by stray frequencies in the neighborhood. Change the frequency on your system and see if the lights go off less frequently.
See the manual for the remote system. You'll need to go into the top of the fan and change some little switches (dip switches) and set the same frequency on the transmitter (what most call "the remote").
Charlie
Aug 20, 2009 | Hunter 52" Ceiling Fan With Light And...
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Hunter Fan Co. 60 In.Brushed Nickel Stonebridge Remote Control Ceiling Fan Logo
1,387 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
