Question about Danby Microwave Ovens
Looking for a manual for model dmw 1001w it was build in 1992
I got a Kenmore microwave hood combination model number 721.80032 is it a hood fan to and how do i just turn on the hood fan
The model number 721.80032 is a partial model number; it indicates the build series. I found the Kenmore microwave, 721.80032700. The final 3 digits indicate the panel color and similar details.
Assuming the microwave was installed properly, it should work as a hood fan. Press the touch pad with the fan icon (underneath it says Hi/Low/Off) to get the desired fan speed. The icon is on the lower left of the control panel; it's below the Cook Time button and to the left of the Light button.
The manual for the 721.80032700 is available here: https://www.searspartsdirect.com/partsdirect/user-manuals/72180032700-kenmore-parts-manual?manualIndex=0 . The direct link to the Owner's Manual is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0710653.pdf . See pages 9 and 14 for using the exhaust fan.
I hope this helps.
Dec 25, 2017 | Kenmore Microwave Ovens
Build-up of soft ice all over in the freezer
Do a manual defrost of the unit. Unplug it.. empty the freezer and place a fan b l o w i n g into the freezer for about 2 hours.
After the manual defrost return the unit to normal service.
If the soft build up of ice shows up again take a very hard look at the door seals. Look for tears.. gaps or any place the gasket is no longer attached to door face
This unit should defrost about every 10 hours. If it does not automatically defrost,,,, doing a manual defrost will only keep the unit going if you repeat the manual defrosting drill every 2 - 3 days.
If it just never goes into the automatic defrost cycle at all, the control board could have failed. PN: W10116216
Item 5 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KFCS22EVMS3/0593/0161000/W1003150/00003?blt=06&prst=&shdMod=
A failed defrost heating element can also cause this. Item 10 this link:
http://www.searspartsdirect.com/partsdirect/part-number/Kitchenaid-Parts/Refrigerator-Parts/12729129/0046/106/Model-KFCS22EVMS3/0593/0161000?keySuffixId=NA&productTypeId=x&searchModelNumber=KFCS22EVMS3&subCompDesc=Unit%20parts&brandDesc=KITCHENAID&modelDesc=REFRIGERATOR&pathTaken=partSearch&blt=11
Nov 18, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
I bought a used Emerson microwave from a neighbor moving out of the building. He did not have an Owner's Manual to give me. I'm trying to find one online but there are so many models that Emerson makes. Is...
The model that you show in the picture is the MW8107WA which has that model number right on the microwave just at the very bottom of the keypad. I'm guessing that you've already looked in the back of yours for a metal plate or sticker that lists your model number on it. Sometimes this information can be found where the door latch meets the door handle on the inside of the microwave.
The manual for the model you have pictured can be found on this very site.
It's here:
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
The instructions are all pretty basic as far as preset buttons and setting the clock and whatnot and so they should pretty much apply to most of the microwaves that Emerson has available.
As far as the instructions regarding weight defrosting of meats and poultry that's usually trial and error anyway.
The best way I know of to see as many pictures of Emerson Microwaves as possible would be to put the words:
Emerson Microwaves
into Google and then click the link for "images" (found near the top upper left the page) instead of the "search" button.
That should bring up plenty of pictures of their microwaves.
Jun 29, 2010 | Emerson MW8107WA Microwave Oven
I have danby microwave m# dmw 1147SS the glass centre dish slipped out and broke I am currently looking for a replacement Please advise. sherry I live in brampton Ontario
Contact Danby Customer Service US / Canada here.
Please let us know if they do not help you.
Jun 15, 2009 | Danby Microwave Ovens
Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
Jan 23, 2009 | Danby DMW1153 Microwave Oven
Missing the plastic ring under the turn table
I'm not 100% sure but 95 that it doesn't have a roller.
Here's the replacement...
https://www.amazon.com/Replacement-Danby-DMW753W-Microwave-Glass/dp/B00YOPH5F0
or ck here too...
www.repairclinic.com
Appliancepartspros.com
All show it without roller.
here's the manual....
https://www.manualslib.com/products/Danby-Designer-Dmw1048ss-193717.html
Best to you.
Feb 02, 2018 | Danby DMW1146SS Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Danby Microwave Ovens Experts
William Miller
William Miller
vince
gbob59
Are you a Danby Microwave Oven Expert? Answer questions, earn points and help others
