Question about Grilling
Gas coming out of valve below regulator, not going
Propane gas coming out of valve below regulator, not going to burners, used yesterday and no problem, but when cut gas on today, started coming out of regulator valve. bad regulator???
  • 57 Answers
Bad regulator you can get it at home depot
Posted on Aug 27, 2009
What is the life expectancy of a gas grill pressure regulator?
I've been in the propane business 28 years and have found regulators from the 1950's still in use today. Regulator manufacturers tell us they should be replaced after 25 years. It should typically outlast the grill itself, which often require new burners, cooking grids, etc. The hissing sound can just be the flow of gas thru the regulator. If you smell gas however, then you should replace it. If it is affecting the pressure to the burners and not getting hot enough to cook properly, then replace it as well.
Jun 06, 2015 | Weber Genesis Silver B Grill
Why does my blue flame ventless propane heater go out for no reason?
Did the gas man use a manometer when the gas pressure was adjusted up? The three basic types are 1. round needle guage capable of measuring approximately 30" water column pressure, 2. U-tube manometer filled with a clear or red glycol, and 3. digital guage.
It sounds like the gas pressure is a few inches water column too high which could cause the pilot flame to actually lift off the thermocouple tip causing flame failure after the gas valve opens. More is not necessarily better when it comes to gas pressure. Normal propane manifold pressure is around 10.5" w.c. with maximum inlet pressure of 14" w.c. This pressure can be accurately measured with one of the above listed manometers by tapping into the manifold downstream of the gas valve or in the pressure tap on the downstream side of the gas valve. Most normal 100% redundant gas controls have an individual pilot adjusting screw in the valve itself for adjusting the pilot size and pressure independent of manifold pressure.
Nov 22, 2014 | World Heating & Cooling
Purchased a used gas oven yesterday. The top burners are working fine, but the oven is sooting up. We live in the country and use propane, but did not receive any additional orfice or instructions. In the...
We need a model number to be specific.
Check the gas regulator and make sure the pressure cap has been set for propane.Most of them are turned over to put more pressure inside the valve.
If so. Check the air shutter on the bake gas tube and adjust for the best color flame.
Also tighten the bake burner orifice with a 1/2 inch wrench.
Oct 03, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I bought a large 5 burner unit 5 years ago.
There are a few things you can check.
1. The burner could be rusted and needs cleaned or repaired.
2. A spider or other insect has built a web in the inlets of the burners.
3. If you are using a 20lb propane tank, it could be overfilled.
4. If you turn off your grill using the propane tank valve and not the valves on the control panel, it may cause the overfill protection device to engage and decrease gas flow.
5. The regulator could be faulty.
6. The jets(orifices) where the gas comes out may be sized to small or may be clogged.
Mar 03, 2010 | Grilling
The flame coming out of the burner bars is small
May likely be low on propane or propane tank gate valve not opened far enough. Otherwise sounds like faulty regulator.
Jan 16, 2010 | Weber Genesis Silver A Grill
My grill does not come up to the proper temperature. There is nothing that seems to restrict the gas flow. There is a sputter sounds so I think the gas feed is restricted. Can you help or suggest what may...
Check to see if the fuel hose is bent or kinked.
• Make sure the grill area is clear of dust.
• Make sure the burner and orifice are clean.
• Check for spiders and insects.
• The regulator has a safety device that restricts the flow of gas in the event of a leak. This safety device can be triggered without a gas leak. To reset the safety device, turn all burners "OFF" and close the Liquid Propane cylinder valve. Disconnect the regulator from the Liquid Propane cylinder and wait 1 minute. Reconnect the regulator to the Liquid Propane cylinder and slowly open the valve until the valve is fully open. Light all burners and observe the temperature.
Sep 03, 2009 | Weber Grilling
Have small gas leak from oven burner oriface when oven is off.
The burner orifice you are referring to is part of the gas valve. You have two electrical connections on it, and the gas line to the valve comes from the pressure regulator.
Apr 29, 2009 | Whirlpool Kitchen Ranges
Low flame on burners
Check the following items:
The propane regulator - and make sure the valve on the propane cylinder is all the way open
The fuel jets (the holes at the end where the propane comes out, usually brass)
The manifolds - they can become obstructed with insect nests
The gas burner valves
The burners themselves, again for obstructions
Apr 19, 2009 | Kitchen Ranges
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Grilling Logo
563 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
