Replace y-pipe with 3 cat converters, replaced plugs, injectors, and the intake. 1000 miles later the intake is melted again.
SOURCE: changing spark plugs 2003 Impala 3.4 eng. i.e. removing and reinstalling upper intake manifold
I have a 2003 chevy Impala and it's not so difficult. Try using a small ratchet that fits in the palm of your hand, I can't remember what it is called. To install the plugs use an extension and put a couple of the card board pieces from one of the spark plug boxes in between the new spark plug and the spark plug puller socket, this will hold the new plug in place while you work with the extension. When screwing in the plug you will have to go by feel so move the extension back and forth like a light jiggle while turning to avoid cross threading the plug. After the plug is tightened attach the ratchet and slightly torque into place.
SOURCE: service engine soon light on 2002 chevrolet tahoe stays on
That normally means that you have a issue with your gas cap try replacing your gas cap first then diconnect the negative terminal of the battery for about three minutes to clear the memory and start the truck again
SOURCE: p0102 Grand Prix
P0102 is ---- mass or volume air flow circuit, low input.
Check the wires going to the maf sensor and at the connection. If all seems ok, you might need a new sensor, seeing how it ran a little better when disconnected.
SOURCE: How many intake manifolds does a 1998 buick park
2 upper pellum and lower intake gasket( both are called intake gaskets) I did it. time consuming alittle but if your ave or above with mechanics then you'll save yourself $2000.. the new pelunum and gasket cost $130 and it comes with improved gasket and a replacement pipe the melts also. lower gasket $40? need more help or info email me! Richie
SOURCE: How to remove the upper intake manifold from the EGR tube.
just hit the upper intake with your hand to the left and that will do i t
