We have a clear see through freeplay/free power radio with solar and a crank . the rubber gasget broke and we would like to get a new on. where could we get one ?
fraid to tell ya it's had it's day and is stuffed, and it's not worth fixin and is worth nuthin. Drop it in the bin an git yerself down to radioshack or Walmart for a new one.
Others said it was the belt. One person replaced it with a rubber band. This is the belt size for Model FPR2SM. It is a neoprene drive belt 78mm (diameter) x 1.2mm x 1.2mm square in cross-section.
One day while cranking the freeplay PLUS Radio on a job site with no power, something inside snapped, and made a horrid grinding noise. All of my co - workers laughed. From then on I only used the radio with the AC plug in adapter.
After 8 years of keeping the freeplay plugged in to listen to it I finally decided to open it up and take a look.
Low, and behold I found some broken pieces that looked like a belt. HMMM?
After a little more investigating I found the 2 drive wheels that power the generator... with no belt on them. I looked in my junk drawer, and found a small blue rubber band amongst the others that I save from packaging items. It looked suitable to do the task. After stretching it around the generator drive wheels, I cranked it up, and IT WORKED!
I'm still waiting to see how long this fix works, but in a pinch... keep some rubber bands and a phillips head screwdriver around. This may be the same problem your having. I'm now getting the long lost last laugh.
It is probably your throttle cable freeplay. If there is too much freeplay the enginge thinks the cable broke and tries to shut it down. Try taking away some of it. It is easily done by pulling back the rubber boot that covers the cable adjuster. I think it should have about 1/4" at the most of freeplay. It should say in the owners manual.
Hi , you have probably expired the battery life out of the radio [ they have a recharge battery life ] but all you have to do is replace those recharge batteries with new recharge batteries and your as good as new
Solution #2 is correct. My Baygen Freeplay radio was running fast and mine had a broken belt. I could not find a belt on eBay. After hours of searching the internet, I fond a replacement belt at http://www.kenselectronics.com/lists/belts.htm I have the older large Baygen Freeplay radio without solar power and this is the belt that fit my radio... AV-SBS9.5 Replaces SBX9.5 & 1407-36 & SCX9.5 square 9.5 x .047" belt, Baygen Freeplay. Just search the website above... they also have a second size Baygen belt that might fit the newer Baygen Freeplay radios???
the drive mechanism has failed. try this. ensure it is fully unwound. then open it. then look for some part of the drive gears or belt that has broken or has slipped off. caution, you MUST ensure it is fully unwound prior to opening it.
I assume that the rechargeable batteries have expired. The trouble is that the batteries are hard-wired into the radio itself. Unscrewing the back and carefully replacing these with similar-rated cells would be possible but difficult. A poor design, which happened to mine too.
In the original big black Baygen radio there is a blue wire with a solder joint that breaks. This wire shunts part of the load back to the generator and prevents it from running to fast and going over-voltage. I am guessing that a similar problem is affecting your newer smaller radio. On the original radio after you take the two halves of the case apart there is a blue wire that comes from the 3v input jack on the back half of the case and goes to the radio circuit board near the top corner. The solder joint where the wire is soldered breaks easily. With this wire broken the generator will run to fast because there is very little load. The radio will still play if you slow the generator with your hand as it is playing back. If you resolder this wire the radio will work and the generator will run at the proper speed. This takes only a moment or two.
