Question about Brother MFC-3240C All-In-One InkJet Printer
Will not print
Display is telling me can not clean, i have check for paper jams, clean print area, i have done everything that the in manual , still printer will not work, i have turn off printer, cancel printing, and still display can not clean
    President:
  • 2,306 Answers
When the ink absorber is full it cannot clean. Ink box needs to be replaced by a repair shop, and the count reset.
Posted on Jul 27, 2009
Where is the ink box located?
Posted on Aug 26, 2009
On Oki 330 have error 380 still showing after paper jam was cleared
Make sure everything is clean. Please refer to your manual for cleaning instructions; or download a new manual at http://www.okidata.com/ .
Below are how to clear a jam instructions:
How to remove jammed paper 28/07/2013
Paper handling is key to Ensure trouble-free printing. However, paper jams sometime Occur.
You can improve feeding and Avoid paper jams in your OKI printer, by following these simple steps:
Loading the Paper: When loading paper, fan the stack of paper before placing it in the tray. This will shake out any paper dust and reduce any static in the paper, two major causes of paper mis-feeds.
- Place the paper in the tray under the tabs.
- Do not fill above the "PAPER FULL" mark.
- Guides Adjust the tray for the correct paper size.
Recommended Media: Use paper specified for the printer
When printing on heavy / thick types of paper, it is best to use the manual feed tray at the front of the printer.This will Provide a straighter paper path to Prevent potential paper jams.
Cleaning: Periodically wipe the rubber rollers inside the area That holds the paper tray with a soft cloth.
dust Paper and simple wear may cause these rubber rollers to slip and not feed the paper properly.
Nov 29, 2013 | OKI C3400n Laser Printer
Installed new maintenance kit for 9050 printer. Trying to reset page count and now the printer is jamming error code 13.02.00.
No relate with paper jam & page count resetting. Might be maintenance not installed properly..Remove paper jams, restart printer,if error 13.20 appears check some paper/paper particles jammed.. 1. Print from manual tray.
A. If paper is jamming, check registration assembly, clean it,best method for cleaning is vacuum cleaner in this area. chk..
B. Take out registration assembly, check clutch gears, driving gears, solenoids..
2. Check pick up rollers are properly installed in tray 2 & 3..
3. Check PIU unit for paper jams
4. Check Fuser sensor flags.
To reset the counter: Hold enter button & switch on the machine, wait till display shows cold restart, scroll to reset maintenance kit with help of arrow buttons & enter. Printer restarts & counter will become Zero..
Jan 07, 2013 | HP LaserJet 9050 Printer
My dcp 150c printer has been jammed for weeks, i have done everything it said in the manual but it won't unjam
This Brother printer could have a piece of paper stuck in it. When a paper jams, assemble the jammed page pieces to make sure all the pieces came out.
A jammed paper can also knock loose the paper detect arm that senses a paper in the machine. This detect arm is usually near the platen (The roller the print head prints against) to detect paper in the machine. If this arm is stuck, it could be sensing paper when there is none.
Rubber paper rollers should all be cleaned with rubbing alcohol or a mild soap solution (I use Windex) to prevent feed jamming.
Mar 28, 2010 | Office Equipment & Supplies
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
Paper Jam
Sep 16, 2008 | HP LaserJet 4mv Printer
Everytime I try to print to my PIXMA 9000 I get an error from the print spooler that the printer is not responding. THe print job starts to print, stalls after a few lines.
OR=
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
Copier canon mf4150 says it has a paper jam, but there is no paper jam.
Hp 5550 printer problem
You have a paper jam. If you have more paper that is left to be fed than paper already printed, pull it out from the feed tray, if not pull it out from the ejection position. You will not harm your printer.
After you do this, turn you printer off. On your PC's desktop if there is still a printer icon near your clock display in the bottom right double click that and then in the window that pops up drop the file menu down and select delete print jobs. Turn you printer off, shut your PC down. Turn your printer on, press and hold the power on button until you receive a test page or use your menu to select print test page. Also, do a nozzle check and print head alignment too all while your computer is off. Once, done, restart your PC. When you have a desktop, go to start menu, control panel or settings, printers. Select your printer to open up the printer properties page. From this, print a test page. If you have done everything right it should print okay. If you still have a printer icon in the system tray (area next to clock display) double click this again, select any print jobs left in the printer and choose resume or print now or print.
If you have any questions your get stuck, use the comment box below to comment back to me. I'll get back to you as soon as possible to help you out. I'm in and out while operating my business.
Regards,
Worldvet
Aug 13, 2008 | HP DeskJet 5550 InkJet Printer
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Brother MFC-3240C All-In-One InkJet Printer Logo
279 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
