Question about Science & Laboratory
How will you track a moving image in the microscope?
    New Friend:
  • 17 Answers
Your question is hard to answer without more detail, including movement rate and required magnification. For relatively slow moving objects you can use a movable stage (X-Y stepper motors tied to a computer). Usually the direction of motion is erratic or unknown, and some digital tracking software will have to be written to drive the steppers so as to follow the designated object of interest. This may be something you have to develop yourself, although there may be some "tracking" software commercially available (or adaptable).
Note that you usually cannot take a video of the object as you track it, due to the quantum action of the stepper motors. However, this does not keep you from taking a series of stills (step - capture - step - capture - step ... etc.) and turning them back into a stop-action video. There are a lot of free or cheap programs out there to do that.
If the motion of the object is rapid, then you have a much bigger problem. One project I did some years back had this problem, and we could not actively track the sudden motion with a microscope. What we did instead was to reduce the microscope magnification, and significantly up the resolution of the high-speed camera (and yes, that was very expensive). At 1500 FPS, we could capture the object as it moved rapidly across the stage, then post-process the resulting frames to center on the object. The obvious limit here is that the object needs to cover a relatively small portion of the overall picture - which limits the magnification you can use. Of course, the offsetting advantage of this method is that you pay more for the camera, but don't have to have a movable stage on the scope.
Posted on Jun 21, 2017
  • Clive
    Clive Dec 06, 2017
    Short duration Spark-lite, a device developed and sold in the '90's, was claimed to have a flash duration much shorter than a standard xenon tube camera flash.
    This used a HV electric discharge to create a brief, 1ns or so bright spark, quenched at tail end of discharge.
    I remember seeing the advert in an electronics magazine.
    The vintage mag advert has no in-depth details of recharge time so for stop-motion 'strobed' video you'd probably need a bank of these.
I just bought an OMAX 40X-2000X Digital Lab LED Binocular Compound Microscope with Built-in 1.3MP USB Camera but I can not install the CD with the photo software so I can not view these images on my...
I do not think so . Most image programs manipulate the image once the vendor software has taken the image Why can you not instal the software
Mar 03, 2015 | Science & Laboratory
What is the other types of microscope ? how do they differ from a compound microscope ?
Compound Microscope
  • Compound microscopes can be found in most biology and science classrooms. They are electrically operated and use light to enhance the image of a cell. They will have multiple lenses for viewing.
Dissecting Microscope
  • Dissecting microscopes are also known as stereo microscopes. They have low magnification and are also light powered. These microscopes can view objects larger than what a compound microscope is able to handle, in three dimensions.
SEM
  • A Scanning Electron Microscope uses electrons instead of light to create an image. These microscopes produce three-dimensional images with high resolution and magnification. They also have a larger depth of focus.
TEM
  • Transmission Electron Microscopes use electrons instead of light to create an image. The material prepared must be very thin. The beams of electrons that pass through it give the viewer high magnification and resolution. These give two-dimensional images.
Jul 03, 2011 | Computers & Internet
I have a Swift SM80 microscope and we are seeing double images. I can't seem to adjust
Sometimes the eyepiece tubes get out of alignment. To check for this, look through the microscope. As you are looking through the scope hold the eyepiece tubes and see slightly "flexing" these tubes with your hands has an affect on the image. If your head is the problem you will be able to flex the tubes until the image is clear. You won't need alot of force. Do not use enough force to bend or break the weak metal. If this works your eyetubes and or head are misaligned. Unfortunately, once a head has been misaligned like this it is not practically repairable.
Nov 01, 2010 | Swift SM95-90HF Stereoscopic Dissecting...
Why should the coarse focusing knob not be used when focusing with the higher-powered objective lenses
There are two reasons. One reason is that when on high power you are working so close to the glass slide that it is easy to misjudge how much you are moving the specimen toward the lens that you can break a slide before you realize it. The coarse focus moves the stage with the specimen on it very fast and you only have a very very short distance within the focus plane before you run the objective lens into the slide.
Secondly, it is just harder to control the minute adjustments needed at the higher powers with the "coarse" focus knob. If you start at the low magnifications find what you want to concentrate on with the coarse focus knobs and then work your way up to the higher powers, you will have very little trouble moving to the fine focus controls at 40x and 100x while still having control of your image.
Sep 17, 2010 | Zhumell LOMO P-111 modular brightfield...
My stage is no longer moving with the knobs.
With one hand push the stage down, and with the other turn the coarse adjustment down. It's a cog alignment issue. The coarse adjustment cog should be turning in order to catch the stage track.
Feb 19, 2010 | Celestron 44320 Trinocular Microscope
Sharper image usb microscope does not work in snow leopard
Wait for an update from the Shaper Image software. If there is not an update, google:
sharper image usb microscope snow leopard compatiable
Put this on your list of reasons why not to get another mac.... xD
Oct 19, 2009 | Computers & Internet
Stage slowly falls causing unfocus
Try holding the Right knob so it does not move, whilst firmly moving the Left knob towards you (clockwise), this is the adjusting method used on Zeiss Jena 1960's High End microscopes, e.g Eduaval & Ergaval.
Good luck,
Alan Mowle
Mar 05, 2009 | Science & Laboratory
Problem with MF-02 binocular microscope stage
I think your problem lies in the way the stage is limited upwards. On top of the stage, right behind it where it slides against the arm, there should be a little screw.  This screw limits the movement of the stage to a certain point upwards.  If the limit exceeds the adjustment gear and its opposing track, then the stage just goes up one notch and then it clunks down.  If you screw it down the stage is limited further down, if you screw it up it's limited a bit higher.  The point of this screw is to prevent objective and slide damage.  Try adjusting this little screw a bit further down and see if it still 'clunks' when you turn it up.  After that we may work on properly adjusting it.  If not, please post again with whatever detail you can provide to aid you with this problem further.
May 28, 2008 | Premiere Microscopes MF-02 Binocular...
Image rings when using Coolpix for microscopy
Under some circumstances when using the Coolpix 4500 attached to a microscope concentric rings are visible as in the below. The COOLPIX 4500 aspherical lens surface is ground to create the ideal curves to gather rays at the focal point with an extremely high accuracy. Such minute lines are not visible in the image taken with a camera alone, however if the camera is used with a microscope, the lines become visible as the depth of field is increased due to the combined F numbers of the camera lens and microscope lenses.
Aug 30, 2005 | Nikon Coolpix 4500 Digital Camera
Science & Laboratory Logo
1,464 people viewed this question
Top Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
