Can it run applemac computers connected? Do we need a different connection cable?
    Top Expert:
  • Computers & ... Master
  • 77,169 Answers
Yes they can be networked together. Just google it.
Posted on Jun 19, 2017
Cant get pictures downloaded from my sony ericsson995 to my applemac though its connected with the usb
Try connecting the phone to a different laptop; preferably a Windows one to see if that succeeds. The Sony website doesn't list any Apple MacOS drivers, so not sure if it will ever work.
Installing the drivers from: http://www.driverscape.com/download/sony-ericsson-w995 onto a Windows PC should let you download the pictures to that PC without any problem.
Good luck !
Jun 28, 2014 | Sony Ericsson Walkman® W995 Cell Phone
I cannot download photos from powershot sx270 hs to my applemac - do I need a softwar? it starts doing it and then stops
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Aug 01, 2013 | Cameras
Pioneer vsx521 stopped recognising hdmi connection from computer
Press the Audio Parameter button (Looks like an x) then scroll up until you see 'HDMI AMP' and hit over to the left or right so it shows 'HDMI THRU' the HDMI will redo the handshake and you should have sound.
Mar 12, 2017 | Pioneer Audio Players & Recorders
I have an applemac pro and I would like to record some digital stills from my GR-D240 onto my laptop. I bought the right cable (I think) from Maplins but the computer is not recognising any device and...
You need a USB cable. Most miniDV cameras that take stills will have a small USB socket on the camera. These vary according to model. There is mini USB as well as Micro USB and other proprietary sockets. Usually the camera is supplied with the camera.
When the camera is connected to a Mac iPhoto should open automatically to transfer the photos.
Jun 29, 2011 | JVC GR-D240 Mini DV Digital Camcorder
No ethernet connection on my computer thats hooked up directly to the 2wire router. how do i acquire ethernet connection?
My guess is that the 2wire router has a DTE plug and a DCE plug. The DTE plug is meant to plug in to your DSL modem, while the other plugs are meant to plug into computers.
If you move the plug, it might work, assuming you have an upstream and downstream connection on the router.
Failing that:
Make sure the cable is an ethernet cable and not a phone cable,
Make sure the wires are run straight through. If it is a crossover cable, it might be meant to connect a DTE to a DTE without a hub, and it won't connect a computer to a router port.
Try a different cable.
Try a different computer (borrow one, etc.)
Jan 18, 2010 | 2wire 2700HG-B Router (2700HGB)
TRYING TO CONNECT NEW PRINTER TO APPLEMACNOTEBOOK
the password it is asking for is probably the administrator password. If there is someone else that uses the computer also they may be set as the administrator and you probably have a normal user account.
YOu need to get the administrator password before you can install the printer. If this seems to be a normal problem for you then you should have yourself set as an administrator(control panel>user accounts))
Let me know if this helps with your problem and thanks for using FIxYa
Jan 07, 2009 | HP Computers & Internet
How to connect 2 PC at a time one of the PC has internet connection i want to communicate both PC I have windows XP sp2?
You can use hub for that matter. Use RJ-45 Cables (Crossover) for connecting just two computers and connect each unit with the cable inserted from your cpu to the hub. To create an RJ45 local area network in Windows, you will need: Several computers running Windows (computers running two different versions of Windows can be part of the same network);
Ethernet cards on a PCI or ISA port (with an RJ45 plug) or built into the motherboard. When applicable, make sure the diodes on the back of the network card light up when the computer is on and that a cable is plugged in.
Dec 23, 2008 | 10 10 Computer 1000 ft. Stranded Wire...
Applemac black powerbook electrical connection
Contact Apple India for replacements:
http://www.apple.com/in/buy/
Sep 26, 2008 | Apple Wired Mediapress X SDI MPEG Encoder...
Software for applemac
Hi, Well, congratulations on the new Mac upgrade.
You will be pleasantly surprised to hear that there is no mac software for any video camera.......
Because all the necessary software for any and all digital video cameras is built right into the MacOS and the iMovie application and the iPhoto Application.
So, all you have to do is connect your camera to your Mac, using the cable that came with your camera, either firewire or USB turn on the camera and then launch iMovie and the Mac will automatically recognize that a camera is connected and it will ask you if you want to import...
Voila Fantastic merveilleux hooolala !!
Apr 21, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
I need to connect to two computers. How do I connect? One computer connecyed John
you connect the two computers in many different ways, 1. you can use a router 2. you can use a port switch or network hub 3. you can connect this two computers thru a UTP CABLE with a cross over connection. after connecting using either any of the mentioned above you need to run the network wizard inorder to have a network.
Apr 19, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
