Question about Toshiba Televison & Video
Humming noise coming from the back of t.v. sounds like the fan
Sounds like the fan but i removed the back panel and spun the fan and i don't think thats the problem some people say it's the colour wheel i would like to fix it myself if anyone could point me in the right direction it would be appreciated
  • 261 Answers
And those people are right, that humming is most probably your color wheel, it's not that hard to do it yourself, but if you're patient you'll get it done right. I believe they have a guide of how to replace it at fixyourdlp.com
Posted on Jul 27, 2009
We have a Samsung FR323TEDBSR french door refrigerator that is becoming very noisy
It sound like the fan motor is going bad. They will spin fine when spun by hand but will start to rattle or squeal when running. if it is the model I think you have the entire panel is replaced as a complete unit. This is not hard to replace. It looks like you have already had the panel out. It just has a couple wire to unclip. and clip the new one in.
May 15, 2014 | Samsung Refrigerators
Lg tv humming noise when tv is on
The humming noise is most likely coming from the power supply.
If the unit is worth the repair cost ( Over $100.00 ) you should have it repaired.
If not, deal with the noise until it goes out.
May 12, 2014 | Televison & Video
Sub zero. 650 reefer. Significant hum coming from top mounted compressor, but still marginal cooling. Now a louder hum and unit no longer cooling.
Hi roger,
I see you concern, and if the unit does not cool anymore and there is a humming noise then you will need to replace or have your compressor repaired no doubt.
Have a nice day,
mvincentc
Jul 03, 2011 | Kitchen Ranges
My Hotpoint makes a high pitched humming noise all the time.
This noise is most likely coming from the evaporator fan motor that is located behind the panel just below the ice maker. There is an air duct that the fan blows through to cool the ice maker that is why the sound is heard in the ice maker area more.
The noise does not hurt anything but the motor can be replaced if it gets too annoying, it is a fairly common complaint. The part number for the motor is WR60X10185 and runs about $60.00. It is a bit challenging to get to but can be done with a bit of patience by removing everything in the freezer and taking the back panel off the inside of the freezer.
Apr 18, 2010 | Hotpoint HSS25GFP Side by Side...
Loud humming noise (vibration) from freezer section when running. Amana refrigerator (freezer on bottom) model BC21VW
Remove the back panel and see if the fan is turning. You will need it in the running cycle with the door switch closed. The noise your hearing is probally the fan assembly AP4008960. Make sure it is mounted tight and the back panel is not rubbing or loose. If the fan is making noise with the panel removed replace.
Mar 24, 2010 | Amana BC21V1W Bottom Freezer Refrigerator
Humming noise coming from left front tire, just started two days!
If the tires are wearing normal then its not the ball joint. If it worse while turning one way and quieter turning the other way it a wheel bearing. A ball joint does'nt make a constant noise.
Jul 15, 2009 | 2002 Chevrolet Impala
The humming noise from my hitachi 42hds69 television seems to have gotten a little louder. This humming sound is more prevelant on various stations. The humming sound seems to be normal/better on dark...
usually it means your screen is going bad unless it is a fan or some mechanical part thats humming if it comes from the screen itself the screen panel going bad.now you can check cables and eveything else for this a signal loss type of short but if you have allready checked all cables or recievers or connected devices for this then its a simple main panel humm means a bad screen panel sorry to say but i hope this helps..
Jun 24, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Nov 08, 2008 | Frigidaire FRS26H5AS Side by Side...
Ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
Humming noise on HP Pavilion dv9000
I have a dv6000 and its makes a insect tlike noise. i returned it and  got another one but that one also made the same noise. so i contacted hp and they told me that the sound is coming from the USB ports, i thought wierd but here is the solution to your problem. go to computer managment (start>right click my computer> manage), click on device manager, select the universal serial bus contollers ( there should be a few roots files that open up), right click a usb root hub and select properties, click the power managment tab, and uncheck "allow the computer to turn off this device to save power". do this for every USB root hub that you have, and the problem should go away. FYI these instructions are for windows XP.
Aug 04, 2007 | HP Pavilion dv9000z Notebook
Televison & Video Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
