Question about Freezers
The motor runns but the freezer does not get cold
The motor runns but the freezer does not even get cold i bought it used and at the time it was working i let it sit two days before plugging it in
    President:
  • Freezers Master
  • 1,922 Answers
Clean your evaporator and condenser coils thoroughly and then you may need to have unit freon cheched
Posted on Oct 05, 2009
Freezer is too warm. We have cleaned all vents but is still in the 40s
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
For further assistance, please let me know.
Regards.
Sep 15, 2011 | Maytag Freezers
It is running but is not freezing the food
Regards.
Sep 15, 2011 | Maytag 15 cu. ft. / 425 liter Upright...
My freezer is no longer freezing
Regards.
Sep 14, 2011 | Hotpoint Freezers
My chest freezer (10 years old) won't freeze. Motor is running and the red indicator light remains on, but neither the amber or green lights are working.
Let's start by diagnosing the freezer;
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Regards.
May 01, 2011 | Whirlpool 10 cu. ft. Chest Freezer...
Wont freeze
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food........
Take care.
Apr 30, 2011 | Turbo Air Freezers
My danby 3.6 chest frezzer has stoped working, it was freezing fine yesterday, now its not even keeping cold
I hope this helps........
Good luck.
Apr 14, 2011 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezer not freezing .. It's cold..
Take care.
Apr 12, 2011 | Northland Panel Ready Upright Built In...
My whirlpool chest freezer runs but does not freeze?
Best regards.
Apr 07, 2011 | Whirlpool Freezers
Freezer stopped freezing. food started getting soft on top. power light on. green light off. tapped it , green light on. less than 1 yr old.
Good luck.
Mar 02, 2011 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
Freezers Logo
59 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
