I have a sears craftsman weed wacker mod.# 358-795542 17in. 25cc
I got new gas lines for it but must have hooked them up wrong, I cant get the gas to move to the carb. can anyone tell me witch line goes where?
I know that the carb is ok and the primer is fine to.
It sounds like you have the lines on correctly but, two things I recommend trying. are to swap the fuel lines around and try priming. If this doesn't prime up the bulb then try changing the cap on the tank. This is a crucial part of the fuel delivery system. It maintains the correct pressure so the gas can make to the carburetor. Hope this helps. Please re-post with updates or questions. If you feel that the solution has helped then please accept and rate. Thanks cj2176.
The line that leaves the primer plunger goes into the carburetor, the other line from the carb is simply an overflow that returns to the (top of) gas tank or pours out in the open.
Hi, I am the one with the fuel line problim.
The way the lines are is, feed line from tank goes to the carb body, primer line goes to tank.
It looks like it builds pressure in tank to push fuel to the carb, could this be the case? If so it is not building pressure in the tank!
Some primers have a in line and a return line, this one only has one line that goes on primer body.
I can see that when I push the primer boulb that it is pushing boubles to the tank.
The gas line with the filter is going to the carb. body and the gas line that is hooked to the primer body is going to the tank. I replaced these lines and now the gas is not getting to the carb. What could be the problim.
AS I stated the carb is good and the primer bulb is good.
