Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Getting no water
I turn on dishwasher sounds like the pump is working but i am getting no water,and the water supply is on? could the pump be clogged and how do i fix it.
The electric valve turns the water on and off. the float switch in the d/w tells the valve when to stop. If the float is stuck on the up position, the valve will not open and no water will come in. The other option is that the control panel is not telling the valve to open. Hope this helps.
Posted on Jul 29, 2009
Ge dishwasher -runs without water
the fill solonoid is stuck or has bad connection on the coil or has failed. it is located within inches of water hook up fitting.
Aug 13, 2014 | GE 24 In. Stainless Steel Dishwasher -...
Dishwasher won't drain properly. Dishes aren't properly cleaned
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Daniel
Oct 25, 2010 | Jenn-Air 24 in. JDB2150AWP Built-in...
Kitchenaid dishwasher will not turn on or drain
Float valve is jammed.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Not working?
Check for a clog internal or external.
Scoop as much water our as you can. Open the cover on the floor of the machine. Usually just turns and lifts out or snaps out some are screwed in. Take your time and try not to force anything. Look for a clog there.
Check for clog in the drain. The dishwasher will connect to the drain under your sink and run either directly to the drain or into your disposal unit. Remove open the connections and look for a clog. Clear if necessary.
Not the clog?
Water is pumped out by the machine via an internal pump located under the base. If it fails the water will collect until it trips the float valve. First scoop out all the water from the machine and run it again. If water comes in and it runs to the point it fills again and trips the float then either the pump or timer is faulty.
Pump check.
Remove the machine. It will be held in place by screws directly into the counter top. You may have to lower it to get it out. The front feet turn with a wrench to lower.
Turn off the water supply. Run the unit again until you get to the drain cycle.
Connect a test light or voltage tester to the terminals at the pump. Check for voltage at the pump. If you have voltage replace the pump. If no voltage the timer is faulty.
Timer problem?
Some can be replaced as a unit others are integral to the control panel. Turn style can be replaced. Touch control can not.
For more help go to my more detailed tip "Dishwasher will not run. DW101 how to fix". Or click on my profile and you will find the link there.
Hope this helped you. Please take the time to rate this tip.
Thanks,
Adrian
Mar 17, 2010 | KitchenAid 34 in. KUDP01FLSS Stainless...
Water doesn't drain out of dishwasher at the end of the cycle.
Following should help you.
Not working?
Not the clog?
Pump check.
Timer problem?
Thanks,
Adrian
Mar 09, 2010 | Maytag MDB9100A Dishwasher
Wash cycle doesn't seem to work. bottom has water
Your gonna have to pull the dishwasher out and shut off the water line. Then disconnect the water hose and get you a bucket. Then turn on the water line to see if water comes out. If water comes out strong then your water supply line is good, which means your inlet port on the dishwasher is clogged or hard water has clogged the little holes in the dishwasher arms. Dishwashers are meant to leave a little water remaining at the bottom to keep the sensor from burning up.
Feb 16, 2010 | Dishwashers
Dishwasher wont drain when finshed
Not working?
Not the clog?
Pump check.
Timer problem?
Thanks,
Adrian
Jan 27, 2010 | Kenmore 15762 Dishwasher
No water supplied
float could be stuck . pull the float inside the dishwasher up and down then try it. could be a bad pump, or angle stop is closed or clogged. if float doesn`t work. turn the water supply line off located under the kitchen sink. make sure it`s off by turning the hot water knob on your kitchen faucet. unplug the unit also under the sink. take the bottom cover off and look for the supply line that goes into the water pump. unscrew the supply line. get a bucket and turn the water supply back on just alittle to see if tou get water coming out. if you do it`s not clogged. so it`s either the pump or it`s the timer switch 9 out of ten times it`s the timer switch. good luck.
Sep 02, 2009 | Magic Chef CDB6100 Built-in Dishwasher
My dishwasher is not filling w water
check filter or drain hose it probably have a dirt,try to fill with water manually and turn on pump to dispossess water,if water not go out and pump work then you have dirt in hose or filter,if pump not work then pump is broken.
Jul 05, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
KitchenAid KUDP01DLWH6 dishwasher filter clog
Follow the main water supply line. It goes to a solenoid valve which is normally located front left side under the dishwasher.
1. Turn off the main circuit breaker for the dishwasher.
2. Turn off Water supply to the dishwasher.
3. Remove lower front panel.
4. Remove Water supply line from solenoid.
5. remover wire connections from solenoid.
6. Remove 2 mounting screws from solenoid.
7. Take solenoid valve out.
8. Look inside the valve where the water supply line was connect to, You will be able to see the filter. it is just a screen and you can easily clean it.
Good Luck
Jun 27, 2009 | KitchenAid 24 in. KUDP01DL Built-in...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
255 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
