Question about Cell Phones
Transfer my music to my Motorola Q as a ringtone via USB cable.
I have a song I want to use as my primary ringtone. I have a cable that came with the phone so I can Sync. I do not have a mini SD card yet. I am unable to Sync and I can not figure out how to get the song over to my phone as a ringtone from my computer. I do not have texting. Any ideas?
  • 175 Answers
Re: Transfer my music to my Motorola Q as a ringtone via...
When you bought the item is there a CD packege in it? if yes install the pc suite for motorola so you can transfer files to you phone storage or memory card.
Posted on Nov 22, 2007
0 characters
3 Points
How can i change the ringing tone of my iphone? can i get music from it's ipod?
You can use the ringtones stored in Settings > Sounds > Ringtones. Otherwise, you can purchase custom ringtones from the iTunes Store application. You can also try using 3rd party applications that are named ringtone makers and try to use music in your iPod application. You cannot set songs in iPod as ringtones directly.
Feb 16, 2011 | Apple iPhone 3G
I want to download an app to download songs and ringtones
Method 1:
Transfer the song(s) you want to set as ringtones onto the microSD card either by connecting to pc via USB or using an SD adapter. Next, Tap on the Music Player, open the music list, press the menu button and select PLAY ALL, this will scan your SD card for music/audio files. Once all your songs have been added to the list, select the song you want to set as ringtone and click MENU key, choose SET AS RINGTONE and that will take you to the RIngtone Trimmer, make the ringtone 30 seconds or less, select Trim and you're done.
Method 2:
Root your HTC Hero, create a directory in your C: drive and name it HeroRIngtones, HTC, or whatever and put there all the ringtones you want to be added (30 seconds or less), then open Command Prompt; make sure your device is connected and already visible. Run the following command "adb push directoryname/myringtone.mp3 /system/media/audio/ringtones" and press enter. Do same procedure for all the audio files you want to set as ringtones.
Method 2 is not available for non-root users.
Dec 17, 2010 | HTC Hero Smartphone
How can i put music on my motorola zn 5 with a usb cord?
You have different options to use to put music on your phone.You could download songs from the internet directly to your phone or you could collect songs on your phone from another phone,laptop or system.Through a phone all you need to do is to put on your bluetooth and transfer,but through the system or laptop you could use the bluetooth too or you could use a usb cable to transfer songs.
Jun 28, 2010 | Motorola Mobility MOTOZINE ZN5 Cell Phone
How to move or download a music file to be a ringtone
This option allows you to transfer music files from your PC. In order to use this option, you must install V CAST Music with Rhapsody on your PC. 1. Open V CAST Music with Rhapsody software. Don’t have V CAST MUSIC with Rhapsody software? Download it for free at 2. Install the device USB drivers before connecting your phone to a PC. USB Cable and Device Drivers can be purchased separately via the Music Essentials Kit compatible with this device. 3. From the main screen on your phone, the SYNC MUSIC V CAST MOBILE PHONE display appears. Your phone should display the message: Connected. Connection may take a few seconds. 4. Drag and drop the song(s) you want to sync from My Library, to your V CAST Music with Rhapsody mobile phone, listed under the Sources tab. Once synchronization is complete, press the END/Power Key and disconnect the USB cable (purchased separately). 5. Under the Music & Tones menu, open My Music to view and play your music. • A compatible USB cable (sold separately) is required for syncing. • Music can also be purchased via V CAST Music with Rhapsody through your PC.
Hope this helps, let me know if I can help you with anything else.
Jun 17, 2009 | UTStarcom Blitz Cell Phone
Unable to load a mp3 ringtone on my Omnia
You should have a USB cable that comes with the phone n the driver for your files transfer from PC to Phone [I hope you got that CD too]. Now first of all install that driver from the CD...when it asks connect your phone to the computer with the USB cable. Open up the File Manager,My Music or you can create a new folder n name it Ringtones n start is very easy once u start doing it. Another method do that via Bluetooth option...take ringtones or songs from somebody's phone. Let me know if there's any prob.
Jun 04, 2009 | T-Mobile Samsung SGH-i900 OMNIA mit 16GB...
I am adding music on SD card, by a Mac, but when put card into ph, it does not transfer to "My Music", it transfer to audio/ringtones
make sure you read the manual about your phone to see which music file format does it support(MP3, WMA etc).
May 31, 2009 | LG Vu CU920 Cellular Phone
Setting ringtone.
hey. I hope I can be some of help, as I used to have the same phone as you and I always added music from my computer to use as ringtones. For starters, make sure the song you want to use is 192 kps or lower, and is in the mp3 format. I usually downloaded my songs via limewire; however, as long as you have the song(s) you want in a separate folder(like your music folder) in your computer documents - it makes for easy transfer from your computer to your cell. Now onto the transferring....
What you want to do is have the usb cable that came with the phone plugged into a usb port on your computer, then plugged into your phone. A little icon will appear in the lower right corner of your computer screen displaying a message - new hardware found(usb storage) ignore that
go to your music folder and right click on the song and select - send to (whatever drive your usb cable is plugged into - for example - :J drive
you should see a grey box appear up in the left corner of your screen displaying the copy animation.
Once your finished with the transferring part, you are going to want to unplug the usb cable from your phone and computer, then look up your sounds file in your phone to make sure it's there and plays.
After the first transfer, it's a piece of cake from there! =)
Oct 09, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Ring tone
This information is from the Motorola Customer Help web pages.
To connect your phone via USB to computer and access your phone's memory card:
On your phone:
  1. Press the Center Select Key
  2. Scroll to and Select Settings
  3. Scroll to and Select Connection
  4. Scroll to and Select USB Settings
  5. Scroll to and Select Default Connection
  6. Scroll to and Select Memory Card
    This directs the USB connection to your memory card. Attach the Motorola Original USB cable to the accessory port on your phone and to an available USB port on your computer.
question.gif How do I use my own ring tones on my phone?
space.gif space.gif answer.gif To put ring tones on your phone using Motorola Phone Tools 4.36c and higher:
  1. Start Motorola Phone Tools.
  2. Choose your phone's profile or create a new profile.
  3. Click OK to wait for a picture of your phone to appear or for your phone to be setup for the first time.
  4. Once the image of your phone appears in the lower right of your computer screen select Multimedia Studio.
  5. On the screen that pops up select Melody Studio.
  6. Select a tab at the top of the screen to find a source for a ring tone. (Samples, My Melodies, My PC, My CD, My Phone).
  7. Select an audio phone you wish to transfer or edit.
  8. Edit the file to your taste or simply choose Transfer to phone.
  9. The file will be put in your ringtone folder.
To transfer music to your phone via Bluetooth(The computer must have a Bluetooth Profile that supports OBEX File Transfer ):
Note: The steps you may need to use to transfer music via Bluetooth may differ from the steps used below. A PC and a Motorola PC850 Bluetooth Adapter were used in the steps seen below.
  1. On your computer
    1. Go to My Bluetooth Places
    2. On your phone
      1. Push Menu
      2. Scroll to and Select Bluetooth
      3. Scroll to and Select Setup
      4. Turn Bluetooth Power On
      5. Push Back (right softkey)
      6. Scroll to and Select Find Me
      7. Press Back several times to return to the home screen
    3. Double click Find Bluetooth Devices
    4. Let your computer search and find your device
    5. Double Click on Motorola Phone (Phone's default name is "Motorola Phone" unless you have renamed it in Bluetooth>Setup>Name
    6. Double Click on OBEX File Transfer on Motorola Phone
    7. Computer will be prompted to enter a Passkey
    8. Enter 0000 on your computer and press OK
    9. Phone will ask if you want to Bond with your computer. Select Yes or No
    10. Phone will then prompt you to enter the 0000 Passkey then press OK
    11. Phone will then prompt to Grant or Deny OBEX File Transfer
    12. Double click on audio Folder
    13. Phone will then prompt to Grant or Deny OBEX File Transfer
    14. Computer will now display a conversations and voicerecords folder. Copy and paste or Drag and Drop your m4a (AAC) or MP3 ring tones to the audio folder and NOT into the conversations or voicerecords Folders.
    15. Phone will then prompt to Grant or Deny OBEX File Transfer to complete the transfer
Note: By putting ring tones on your phone using Bluetooth or Motorola phone tools, you may not be able to remove the ringtone from your phone. Motorola is aware of this and in the future removing the user added ringtones
Jun 10, 2008 | Motorola Mobility RAZR V3
if you already transfer them to you mobile you should be able to to go to sounds in your phone and apply them.
Mar 19, 2008 | Motorola Mobility RAZR V3
Features of your phone:
Compact and thin
• Brilliant TFT internal display with iconic CLI
• Calendar with event reminder (alarm), alarm clock, stop watch, currency converter, calculator and ringtone composer
• MP3 ringtones and FM Radio (play FM radio thru speakerphone w/ headset plugged in)
• Stereo support via 2.5mm headset jack, send/end headset support
• Speakerphone (office quality)
• Messaging: SMS, MMS, EMS, and SMS Chat*
• 100 entry internal phone book with picture phonebook on phone vCard send/receive via MMS*
• VGA Camera with 4x zoom (1x, 2x, 3x) with special effect options GPRS Class 8 (1 up/4 down)
• WAP 2.0
sorry your phone does not support music files (mp3,acc,ect.)
Jan 19, 2008 | Motorola Mobility W375 Cellular Phone
Cell Phones Logo
645 people viewed this question
Top Cell Phones Experts
IT Solution
IT Solution
Are you a Cell Phone Expert? Answer questions, earn points and help others
