Question about Bosch Saws
After changing the blade on a bosch 1587VS jig saw the blade turns sideways when sawing. How is this corrected? Thanks
  • Anonymous Mar 29, 2014
    Need operating manual
  • 2,176 Answers
I would recheck the installation of the blade and the tightness. If still a problem there is a spring under the lever that might have broke (they tend to do that) and is jamming the spindle. Let me know and I will help you with the breakdown for this tool
Posted on Jul 26, 2009
How to change blades on a bosch 1587avs
Turn the handle on the top counterclockwise like shown in the video.
But the handles break often, see the link for a parts breakdown
Bosch nbsp1587AVS nbspTop Handle Jig Saw
Feb 09, 2015 | Bosch 1587Avs Jig Saws
Jig saw b4300 blade replacement
This tool has no mechanism for the fixating ot the saw but only a short ***** part 53 its a fault in the manual , it simply replace the saw with a screwdriver. or simply the clamp ***** to release turn it loose and from the top you can replace the clamp *****
Bosch B4300 0601582535 Jig Saw Parts
Sep 05, 2013 | Bosch 1581AVSK Top Handle Jig Saw Kit
Bosch b4300 jigsaw blade replacement
To change the Bosch B4300 blade - If the grey knob does not turn to release the broken blade, you need to use a LONG THIN flathead screwdriver down the center hole at the top. Unscrew until the broken blade is loose. Pull out. Replace the new blade and then screw the it tight through the same hole at the top. DONE.
Jan 25, 2012 | Bosch 1581AVSK Top Handle Jig Saw Kit
How do you change a blade in the Bosch Jig Saw Model 1587 AVS
Pull the black knob on the top front of the handle up and turn it clockwise to tighten and counterclockwise to loosen. I'd turn it counter clockwise at forst just to make sure it's loose enough to accept the blade when you start.
Sep 01, 2011 | Skil 1587AVSK - Bosch Jig Saws Power Tools
How do I change a blade with the Bosch 1587VS?
you need to lift up on the knob to loosen the spindle and remove/install the blade. To install the blade you might need to turn it some and push up and when it is straight then you need to turn the knob while holding up on it till it is snug and then push the knob down.
Jul 10, 2011 | Bosch 1587avsp Vs Orbital Jigsaw
I need the schematics for my bosch jig saw (1587VS)
I have a blue wire that came of itscomes from the triger and goes to the motor can't find out where it goes need help
May 19, 2010 | Bosch Saws
My bosch jigsaw keeps saing sideways!!!
could be the yoke inside that is loose, unplug the tool and lock the blade in and see if you can turn the blade by hand. also make sure that you are using the right shank blades and lastly is the locking mechanism fully engaging the blade. Let me know the model number if none of these help and I will look at an explosion for you.
Mar 18, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
Blade wont stay in Bosch 1882VS jig saw
ARE YOU USING BOSCH BLADES IF NOT GET SOME THEY ARE MADE A LITTLE DIFFERENT THAN SOME OF THE OTHER BRANDS AND FIT A LITTLE BETTER , IF YOU ARE THEN DO NOT KNOW
Feb 22, 2009 | Bosch 1587AVSK 5.0 - AMP Top Handle Jig...
Blade Change for Bosch 1581
the screw is a flat head but you need a long series screwdriver you have to loosen the screw first then turn the blade sideways remove then place new blade in sideways turn to straight then tighten screw again its not too hard at all best of luck glenn.......
Nov 11, 2008 | Saws
BOSCH: 1581 VS... BROKEN BLASDE HOW TO REPLACE WITH NEW BLADE
hi there is a hole on the top of the handle at the front when holding it it is just in front of your hand you need a long series flat head screwdriver to loosen turn the blade sideways and out she comes
hope this helps glenn...........
Nov 09, 2008 | Saws
Saws Logo
938 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Craig Butler
Craig Butler
Are you a Bosch Saw Expert? Answer questions, earn points and help others
