Question about Garden
Pump sounds extremeley loud and the governer wont kick on when wand isnt being used.
2 Suggested Answers
  • 306 Answers
SOURCE: fuel pump wont turn
Well - there is a pressure switch somewhere that shuts off the pump when it reaches the correct pressure. The fuel filter may be clogged so the pump turns off real quick. check the fuel pressure rail test port connection.
Posted on May 08, 2009
Vacuum works quietly and well when using the wand attachment, as soon as it is lowered into 'floor vacuuming' position it makes a very loud noise but doesn't seem to lose suction.
Hi Ismaias, it's Jack at Dyson.
The issue you're describing sounds unusual. If you think the noise coming from the cleaner head and brush bar is excessively loud, you might like to follow the steps shown in the video below to make sure nothing is jamming or obstructing the brush bar:
If you're confident there are no obstructions, but your machine is still sounding much louder than it should be, please do not continue to use your machine. At this point, it would be best to contact the Dyson Customer Helpline directly so we can provide further assistance. If a repair or a replacement part is needed, we can also confirm if this is covered under your Dyson warranty.
When you have your DC50 to hand, please give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Mar 22, 2015 | Dyson DC50 Animal Upright Vacuum Cleaner
My washer isnt wanting to pump water out like it use to and the spin cycle isnt wanting to spin ,the pumps is making a loud un normal sound.i checked filters they are fine.lots of lent is coming out w
Your drain motor is likely failing slowly. Lint cleaning is a great maintenance step but over time there's lint and debris build up on the motor and probably drain lines. Check your drain hose to make sure it's clear as an easy fix. Otherwise look to getting quotes on parts replacement, starting with that motor.
Nov 09, 2013 | LG Washing Machines
My tahoe acts like it is going to start but wont like it isnt getting gas. i had pump replaced approx. a year ago
The pump could have still went out. Spray a little starter fluid in the throttle and have some to start it. If it starts keep spaying it a little to keep it running. If it cut off, then most likely the pump or filter need to be changed. Or a fuel pump relay keeping the pump from kicking on. Usually you can open your gas cap and have someone to just turn the ignition on while you listen at the gas hole for a faint or buzzing type sound. This is letting you know the pump is kicking on.
May 29, 2011 | 1999 Chevrolet Tahoe
Dodge 2002 intrepid ...serging wont go above 2500 rpm like the governer is kicking in..
i really don't think they have a goverenor..i believe its called a rev limiter...although that's what sounds like is happening, i believe it just may be a fuel issue..perhaps a plugged filter, or pump maybe going. Have it taken to your shop..i have seen, if the spark plugs are bad, then it will also cause the underlying condition as well...so there are a few ideas....my advice is get a tune up anyway, plugs, fuel filter, air filter...then if the problem is fuel pump, do the strainer and fuel filter and air filter at the same time...to eliminate any further problems.
Nov 18, 2009 | 2002 Dodge Intrepid
My pump stopped working after 1 month. It was running loudly then kicked the GFI in the plug and wont reset now.
unplug from gfi reset and plug something else in and see if it works, no then bag GFI, yes then sounds like pump is faulty return to place of purchase i would not recommend trying to fix yourself as some one could get electrocuted in pool if theres any mistake
Jul 07, 2009 | Intex Easy Set 530 Gallon Swimming Pool...
Water won't come out like its blocked
Water won't come out when you brew coffee or use the steam wand?
If its when you are using the steam/hot water valve the parnello might be clogged.
If it is when you are using the brew head, then try backwashing the machine with espresso machine cleaner(Purocaff or Cleancaff).
The pump could also be blocked, or the spring in the pump might be damaged, open machine and check pump.
May 15, 2009 | Saeco VIA Venezia
Fuel pump wont turn
May 01, 2009 | 1995 Buick Century
No sound from fuel pump
First if there is no sound coming from the fuel pump always look in your fuse panel for a blown fuse. If a fuse is blown for the pump if it is electrical you should hear the pump kick on when you replace the fuse and turn the ignition. If there is no sound and the fuse isnt blown then you have a faulty fuel pump.
Apr 07, 2009 | 1995 GMC Jimmy
Steam wand works, but no water for espresso
I have found that I have to remove the group valve assembly about once every 1 or 2 months to clean out the .030" to .040" opening in the valve body. The manual gives instructions on how to do this. It becomes clogged with a thick paste like substance.
Jan 24, 2009 | Gaggia Carezza Espresso Machine
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
